Heat Shields
Old Feb 5, 2017 | 02:35 PM
EddyManure's Avatar
EddyManure
Default Heat Shields
How many heat shields came with a radio equipped 69 small block?
Old Feb 5, 2017 | 02:46 PM
Alan 71's Avatar
Alan 71
Hi EM,
The number of 'heat shields' didn't have anything to do with the radio interference shielding.
All sb cars got a small J shaped shield at each pair of spark plugs and each side of the block had a 'boomerang' shaped shield that the 2 forward spark plug wires ran through.
Cars that had a radio as an option got the set of chrome plated shields in addition to the heat shields.
Regards,
Alan
In this photo the right side HEAT shields are the 3 lower pieces, plus the small wire loom bracket.
The left side boomerang HEAT shield in place.
Old Feb 5, 2017 | 03:10 PM
EddyManure's Avatar
EddyManure
Alan
Thanks for the prompt reply. Why won't my left side chrome static suppression shields fit over the heat shield covering the number 2 and 4 plugs
Old Feb 5, 2017 | 03:12 PM
EddyManure's Avatar
EddyManure
Sorry, I meant number 2 and 4 plugs
Old Feb 5, 2017 | 03:38 PM
Alan 71's Avatar
Alan 71
Hi EM,
Sorry, but without seeing your parts and their instillation it's difficult to say.
It has to be the right shaped chrome shield to fit over the right heat shield.
And the right brackets need to be used to mount the radio shields.
Picture?
Regards,
Alan
Old Feb 6, 2017 | 08:10 PM
Rescue Rogers's Avatar
Rescue Rogers
Is my vette stock?? HAHA
2016 C3 of Year Finalist
Alan, in your pic, where does the shield with the hole in it mount. Its the one in the center
How does it mount as well
Old Feb 7, 2017 | 09:14 AM
Alan 71's Avatar
Alan 71
Hi RR,
It's the right rear radio noise suppression shield.
The hump and hole is for clearance for the CEC/TCS temperature switch in the right side head.
Regards,
Alan
Old Feb 7, 2017 | 09:39 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by EddyManure
...Why won't my left side chrome static suppression shields fit over the heat shield covering the number 2 and 4 plugs...
I'm lost. #2 and #4 are on the passenger's side. Anything left side would be the driver's side. Do you mean #1 and #3?
To Heat Shields
