All Hi-Performance 427 Big Blocks 66-69 had the second design 3/8" rod bolts with double dimple.
The third design rod with 7/16" rod bolts were for the 69 L88 & ZL1 options.
For what its worth I have the 6332 crankshaft in my 427 390 hp, great crankshaft.
the guy(who died 25 years ago) that owned all of this was into building and racing engines, so just because parts came with the block is no guarantee thats whats came out of it.
the more I google, the more conflicting info I find.
the 6223 and the 7115 crankshafts seem to almost be interchangeable number (search enough and there are ppl pulling 6223 cranks out of 7115 boxes) so I'm not real concerned and will use the crank I have.
my main concern is what rods were originally be in the motor. i continue to find conflicting info on this. some sites say the 7/16 rods were only l-88, others say they were use on any 427.
is there anyone on the board who has actually torn down there L71/L89 and can say what was inside it?
if you look at the Chevrolet Corvette Parts and Illustration Catalog Group 0.603, ROD, Engine Piston you will find the L88 did not use the same part number for the rod as the L71/L89 in 1968
The term HD is the L88
The term SP. H/PER is the L71/L89
68 Y(427) W/HD (1st Design) 3909846 Rod (Pink) (3/8 Bolt)
68 Y(427) W/HD (2nd Design) 3969804 Rod (7/16 Bolt)
65-69 Y (396,427) W/SP. H/PER 3856240 Rod (Ident Rib on Conn Rod Cap) (Blue)
So maybe the 3/8 dimple rods and pistons were out of this motor. That's good I'll be saving money!
Depends what your "usage" will be. NCRS never looks at engine internals, therefore you should (and I would) use the "BEST" internals available, regardless of part number.
IF memory serves, the L88's used full floating rods- none of the others did. That would explain the different part number.
969804 - 1969 Zl-1 L88 Forged Connecting Rod Assembly - NOS GM
This NOS GM heavy duty ZL-1 L88 Forged Connecting Rod, GM part number 3969804 is finished for floating wrist pins. It is manufactured from 4340 steel, magnaflux inspected and shot peened. Included is super quality 7/16" boron steel bolts. This rod is color coded green. This is a NOS (new old stock) item that is limited to quantity on hand. Once they are gone, they are gone forever. Get them while you can.
