Plastic Fantastic tew
Old 10-18-2018, 08:33 AM
  #201
Rodnok1
Rodnok1's Avatar
Very interesting so far...
Old 10-23-2018, 10:31 PM
  #202
bfit
bfit's Avatar
I started down this same road a while back , I was pointed at your thread when I posted that I am thinking about fitting a Camaro rear end in a c3 frame.
I have some info on the c5/6 suspension that I found on the net that are sort of legible.
I will email you a copy if you cant read it here , just PM me your address
Bfit
SuperBuickGuy (10-24-2018)
Old 10-24-2018, 10:08 AM
  #203
SuperBuickGuy
SuperBuickGuy's Avatar
Bfit
that is a lot clearer, thank you.
Old 10-24-2018, 07:43 PM
  #204
bfit
bfit's Avatar
I sent email form my work address, there will be info an the footer just ignore it
Bfit
Old 10-25-2018, 04:49 AM
  #205
bfit
bfit's Avatar
‘I found the drawing right here on this forum
https://www.corvetteforum.com/forums...dle-angle.html
Small world
Bfit
Old 11-14-2018, 12:57 AM
  #206
RBrid
RBrid's Avatar
Does that mean that the front tires won't stick out from the fenders anymore?
Old 11-14-2018, 05:58 AM
  #207
CraigH
CraigH's Avatar
Is it just me and possibly my less than stellar internet connection but I can’t ever get all the images to load on this thread.
it. Looks like a great read and source of information.
are the images very high resolution, other threads seem to load fine.
Craig
Old 11-14-2018, 07:36 AM
  #208
bfit
bfit's Avatar
I have the same problem, even at work where I have the famous Australian NBN fast internet .
This is an interesting thread
bfit
Old 11-14-2018, 12:04 PM
  #209
SuperBuickGuy
Craig
it's even more annoying when you're uploading those pictures. Ah well, for the price I pay I'm not complaining.
Old 11-14-2018, 12:05 PM
  #210
SuperBuickGuy
I tried the tires on with the back mount in the right place - so while I'm not sure, I don't think it's enough.... have to get my wheel measurer out to verify, though
Old 11-22-2018, 11:44 PM
  #211
SuperBuickGuy
ah turkey day.... not much accomplished other then driving 400 miles
but still time to talk ofsets
whether anyone likes it or not, 20s is all that fit... .20x10 front 20x12 rear (though this could go to 14 if I so choose)
front 2 3/4" = 69.85 mm, 20x10 - 254 mm width. divide by 2 = 127. 127-69.85= 57.15 mm or 58mm positive offset on a 10 inch rim (which is a custom size, the best I've found is in the 40s)
rear 4"
math 20x12 = 304.8/2 = 153.9-101.6 (4 inches) = 52.3.... interestingly, the rears tend to be nearer zero or further out in the 70 range.
oh yeah and one more thing.... yes, that is suspended on the spring
did that by welding tabs on the top
hopefully Sunday I can start making the rear suspended
Old 11-25-2018, 09:20 PM
  #212
SuperBuickGuy
bmw 750il wheels work
and yeah, Custom Image Flares got me again.... the opening isn't the same right to left; that said, it's not a huge thing to fix - but it does give flesh to the warning I got from the guy whose C3 was the template for the flares (don't finish the flares until you have the wheels)
but the offset works
and it doesn't hit the wheel opening when turning
thankfully the right side is correct.... so it's just a matter of copying
back side looks good.... the 'real' wheels will be wider, but this, for now, works
*sigh*
I should point out, that the wheel will be out about another 1/2" in the front - because of the rotor and the brake mounting bracket.... so it was going to get changed anyway
Old 11-28-2018, 12:11 AM
  #213
SuperBuickGuy
leveled the nose and it is close enough that I'm not going to mess with it - Keep in mind that I'm painting this black (or a dark color) so edges really blend
progress pictures
I need to brace the rear assembly, before the body lift
then I need to lay the coil over over... so that's a notch
how, in all that's holy, does fiberglass look like it rusted?
ugh
thankfully I have sawzall blades.
Metalhead140 (12-02-2018)
Old 11-28-2018, 06:02 PM
  #214
SuperBuickGuy
boy, tough crowd
Old 11-29-2018, 12:08 AM
  #215
SuperBuickGuy
a few minutes and got it on the ground
a bit of frame notching
and voila a roller again
it does need the wider rear tires..
Old 11-29-2018, 09:13 AM
  #216
gtmsomeday
gtmsomeday's Avatar
Default and voila a roller again
That was easy!
Old 11-30-2018, 12:44 AM
  #217
SuperBuickGuy
moving along time to make the coil overs permanent
it's getting close to time to get a few more tab plates lasered out
so when I do the finish work, all this will get boxed and finished
for now it's strong enough to drive
all I did on the lower arm was redrill the hole
now to connect the steering wheel to the front
basically, take the u-joint off the top and replace it with the lower one.... and in this case, had I not had the u-joint, I may have done this a bit different....
heat removes it
test
the issue
basically heat puts the new one back on....
and now it steers.. what's left there is to replace the motor mount and clean up the frame... which I'll do when I pull the body off (likely Sunday)
To Plastic Fantastic tew
Old 11-30-2018, 09:27 PM
  #218
Rodnok1
Rodnok1's Avatar
That's alot of frame removed for rear coilover mnt, do you plan on bumping over it, adding frame rail to inside?
Old 12-01-2018, 05:27 AM
  #219
SuperBuickGuy
no need. the Camaro structure has its own frame. If anything, once the body is off, I'm going to look at removing the C3 frame from the frame junction to the rear mount. That said, the extra 20 or so lbs of that section is beneficial over the rear thus reducing even more the need to remove.
with that said, there will be more metal work done where the frame of the C3 and the front of the Camaro frame meet - again, that will be once the body's off (which is soon).
Old 12-03-2018, 12:05 AM
  #220
SuperBuickGuy
hateful task ahead
but I finally afforded myself a power bleeder for when I get brakes
random rear picture
Quick Reply: Plastic Fantastic tew
