Plastic Fantastic tew
#282
first, make holes (aka void warranties)
weld a bit of aluminum
dang, the appearance I know what I'm doing....
fit an Astro top
(I love these things)
fit an Astro top
#284
Brakes
Today I received the bolts for the front calipers.... time to finish this up
first a bunch of milling on what I welded yesterday
I resisted the urge to sharpen the carbide (I should have but it worked)
then drilled the holes
wow, it works, errr... well that's no surprise that it worked just like I planned
Installed new upper ball joints
for the life of me, I can't figure out why this is an issue now - but one bolt should be shorter to attach the hubs.... thankfully, Mr. Cutoff wheel came to the rescue
and look, the rear
and the front - to be honest, I don't know of a 14" rotor for this application (the C5 uses a 13")...
Getting close to final assembly
and the rear
and look, the rear
and the rear
#287
so I've been waiting on some parts to arrive so I can finish up the frame
such as rebuild parts for the C6 front suspension
it was cheaper to buy this as a kit then individually... and hate on Chinese (like I do) but they put lube points on all the moving points... I guess we got too smart for that?
and fuel line....
which I bought twice not knowing that aluminum is advised against by FItech.... ah well, it was really cheap and I'll use it for other stuff... new brake line is under that stack too
Got around to removing the seats and carpet for the next phase
what I wasn't waiting for was more metal work inside.... this is why I like up to 75... no metal floors, or speedholes in the metal floor
I'll get on fixing this Thursday... ah well. This year finish goal was more of a hopeful guess.
hopefully the readers enjoy the faster loading - I'm using "huge thumbnail" it loads light years faster at the expense of clarity.
and fuel line....
The following 2 users liked this post by SuperBuickGuy:
gtmsomeday (04-10-2019),
Metalhead140 (04-10-2019)
#288
extent of the problem
passenger side is fine
Needed bench space so put the tank roughly in place
so the plan.... at $300 plus shipping, there is zero chance I'm not building a replacement part(s) myself for the floorpan...
#290
Dementer sole survivor
Received 6,294 Likes
2016 C3 of Year Finalist
I did the same thing for an early 70's Jeep I had to rebuild. Welded in nicley and it was thicker and stronger than the original....
Good job
Good job
#291
Foretaste of the Buick wagon that's coming next
cut hole, remove undercoating
remove metal from flange
spray with weld-through primer first to mark the edges
eventually I'll weld this on both sides, but this is a start
and finally another project in the wings
initially I was/may weld this - but the cap retainer would need another solution
#292
love the innovation and attention to detail here. I really enjoy following your thread. Keep up the good work and that billet cap looks amazing =)
#293
Finish up the floor detour
a few notes.
1) the floor is going to get the ceramic coating that the FJ40 got - it's 1/4" thick so those seams disappear as does the rust pits on the other side
2) underneath it gets undercoating so the patch will fully disappear (like it did on the '40)
3) FOR THE LOVE ALL THAT IS HOLY STOP BLOCKING WINDOW CHANNELS WITH ADHESIVE WHEN YOU HAVE A LEAK... damn fools, GM designed the windshield system to allow the water to run under the molding then away from the car. The molding keeps water from being driven into the windshield frame. This car had a leak, and they plumb filled up the channels with window adhesive.... the leak is in the valley (below the window) .... just remember this, if I see you, Bubba, doing this I pray for your eternal soul to be damned to a hell where you do nothing but try to weld up pinholes, naked, and over your head. Prayer works, so you are now on notice there is an 11th commandment.
onto cleaning the body so I can complete the color change
and rebuild the rear floor... I think I'm simply going to raise it to clear.... there's little reason to give it huge luggage space and it's far easier to just bond it back 2" higher.
a few notes.
#294
more.... I spent most of the day on honey-dos, so I had 2 hours tonight to get further....
doors are off
I knew pulling the booster was a pain, double the pain for a true 4 speed car because there are more bits in the way
however, I won
ish.... I still have to put the other back in
ah well, having brakes that will suck the tailights through the gas tank will be awesome.
doors are off
however, I won
#295
Nam Labrat
Received 4,178 Likes
"Ahhhhhhhh…..the thrill of restoring C3 Vettes.....it has to get real ugly before it gets real pretty"
#296
not really restoration, the center of the frame is similar to stock and the top of the car, from the fender edges up is stock..... except the gas fill.... nose and tail are not.... lights won't be, hood is an idealized version, interior may have one or two bits... motor, not at all... trans is, for the moment stock.... but how bent and beat this was, this is the best use of it.
Hydraboost
cut on the line
bright side is the plate fits, down side is the hole is too high
by an inch
unthread brake pivot
verify thread pitch
cut and thread
verify distance
I've had this Corvette style MC forever, it has the right internals, but the thread pitch is completely wrong for anything I've had before... more likely it will continue to be a test part... but it's nice to have one to check before I buy.
other end, using the right master cylinder
not the right one
Hydraboost
cut on the line
by an inch
verify thread pitch
cut and thread
verify distance
not the right one
#299
it feels slow from my chair... but thank you, I appreciate the compliment
I didn't get much done today, but a bit did get accomplished
like making a hole bigger
ground on this then painted it
goal here was to set the height of shelft
once I finish the booster, I'm pulling the body off again to glass the shelf, the inner wheel wells, and the inner fenders, then, of course, plumb the frame. Hopefully when done with that list the body goes on for permanent
Metalhead140 (05-02-2019)
