Front spring question
Old Feb 14, 2017 | 11:36 AM
jroyse's Avatar
jroyse
Default Front spring question
Swapped engines, removed all A/C components, now have aluminum heads, intake & so on. Front end sits about 2 inches to high. Are new spring the way to go? I so what kind?
Thanks for any help you can lend
Old Feb 14, 2017 | 12:26 PM
Dynra Rockets's Avatar
Dynra Rockets
As far commonly available, over-the-counter stock diameter springs go you should look at the 550's.
I did the same and stock springs were 1.5" taller, 460's were 2" taller than my original stock height and 550's were about .5" shorter than my original stock height (less free length than 460). YMMV.
R
Old Feb 14, 2017 | 03:07 PM
resdoggie's Avatar
resdoggie
Had a 1976 L-82, 4-sp
Royal Canadian Navy
I did the same mods. I just removed the stock springs and cut one coil off each spring. It lowered the front about 2".
Old Feb 15, 2017 | 12:01 PM
jroyse's Avatar
jroyse
Default front springs
Was hoping to find a progressive spring of some sort but maybe I'll just go the easy way and cut one coil off.
Thanks for the help.
Jim
Old Feb 15, 2017 | 12:24 PM
Jebbysan's Avatar
Jebbysan
Dr. Detroit
Same here.....cut a coil off of a 427/400 and it dropped it about 1 1/2.......
If you do it right this is a cheap, easy and safe mod. It even increases the spring rate a bit.
Jebby
Old Feb 15, 2017 | 09:44 PM
jroyse's Avatar
jroyse
Jebby
Started on spring removal, but try as I may I cannot get the ball joint loose from the control arm. Beat on that pickle fork for 30 minutes. and nothing moved. Really destroyed the ball joint boot though. Got any ideas?
Old Feb 15, 2017 | 09:50 PM
Jebbysan's Avatar
Jebbysan
Dr. Detroit
Get a pickle fork for an air chisel....make sure it is narrow enough....there are two common widths.
Too wide will not give you the wedge you need.
Jebby
Old Feb 16, 2017 | 12:27 AM
The13Bats's Avatar
The13Bats
I dont mess with the forks i use this kind,
When i did my 66 it popped off with such a bang my neighbor thought i shot something....
Old Feb 16, 2017 | 12:40 AM
hzz's Avatar
hzz
It works very well.....and yes, it's a BIG bang when it pops loose
Old Feb 16, 2017 | 05:33 AM
540 vette's Avatar
540 vette
I take my spring out by taking the inside bolts off the control arm. The ones that hold it to the chassis. It is easier and you won't have to bang the hell out of the ball joint and rip the boot. Put a spring compressor on the spring (run it up thru the shock hole, look it up) and then remove the bolts and swing the control arm out of the way. I can do one side in about 20 minutes.
Old Feb 16, 2017 | 04:36 PM
jroyse's Avatar
jroyse
Like your idea about removing inside bolts. I now have to remove my control arm cause I have to replace the ball joint. Now another problem, cannot get the big bolt loose on the control arm. tried impact wrench, flex bar with 30 inch extension, still nothing. Is it threaded into the control arm? Must be. Forgot to say, yes the ball joint is loose.
Old Feb 16, 2017 | 08:39 PM
540 vette's Avatar
540 vette
No that bolt goes thru the frame, no threads. It may be rusted in place. Hit it with some penetrating oil.
I learned that way when I went to school for GM.
Old Feb 17, 2017 | 12:44 PM
Rescue Rogers's Avatar
Rescue Rogers
Is my vette stock?? HAHA
2016 C3 of Year Finalist
Are you talking about removing the lower A frame when you say control arm?
Old Feb 17, 2017 | 01:28 PM
jroyse's Avatar
jroyse
Yes. I now have everything off and spring out but lower A frame will not come loose. The rear most bolt appears to be holding the thing in place. So far no amount of prying, pounding, penetrating oil or anything is working. I'm ready to replace the ball joint, cut the spring and put it back together without new bushings. I'm I missing something? Didn't expect this to be so difficult.
Old Feb 17, 2017 | 09:49 PM
Rescue Rogers
any pics off whats going on?
Old Feb 18, 2017 | 10:53 AM
jroyse's Avatar
jroyse
Default lower a arm pictures
Here's a couple pictures showing the stuck a arm and bolt.
Old Feb 19, 2017 | 09:29 AM
Jazzyced's Avatar
Jazzyced
I just did mine and that bolt was a very tight fit.
I had to support the lower a arm to prevent any shear stress or bending momentum on the bolt. Also I put back in place the 2 smaller bolts to maintain the alignment.
With that in place, I used a pin chaser to push the bolt out. Once aligned and the weight supported, it came out relatively easily. Or at least as easy as it could be on a 40 yo car with some rust...
To Front spring question
Old Feb 19, 2017 | 09:42 AM
resdoggie's Avatar
resdoggie
Royal Canadian Navy
Put the nut on the end of the threads and start tapping it up with a bfh? Mine came out easy with wrenches. GL.
Old Feb 19, 2017 | 09:50 AM
sparky77's Avatar
sparky77
Put the nut back on the bolt just so the bolt and nut are the same on the bottom and hit it a few times with a hammer should loosen it up,if that doesn't work a little heat with a propane torch on the a arm around were the bolt is will help.
Took Me to long to type !
Old Feb 19, 2017 | 01:36 PM
jroyse's Avatar
jroyse
Default lFront lower a from stuck
Well I've tried all the above suggestions to an avail. Even used my air chisel on the bottom of the bolt, nothing will move. Managed to get my impact wrench on the top of the bolt but it still didn't budge. I hate to try a torch with the fuel pump sitting right above. Sooo I'm done. Just going to replace the ball joint and put it back together without replacing the A frame bushings. Thanks for all your help. I know you tried.
