Overspray clean up
Old Feb 24, 2017 | 09:50 AM
PonchoVette's Avatar
PonchoVette
Default Overspray clean up
Hi Folks-
I've been in the middle of restoring the interior of my 81.
I redyed and clear coated my seat backs, and used 3M adhesive spray to install new carpet on the seat backs. Everything is looking good, but I have just a little adhesive overspray on the seat backs that I need to clean up.
What is the best product to use that will remove the adhesive overspray without stripping the new dye and clear coat? Looks like denatured alcohol and acetone may be more aggressive than what I want-
Thanks!
Old Feb 24, 2017 | 10:16 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
I would think the directions on the can of adhesive would say what you can use to remove it.
Old Feb 24, 2017 | 10:41 AM
PonchoVette
All it says is, "when using solvents for cleanup, follow the manufacturers recommendations..."
I've got all sorts of solvents, I'm just worried that what I have might be too harsh and zap all the work I've done to this point.
Old Feb 24, 2017 | 11:19 AM
suprkoop's Avatar
suprkoop
I'd get a piece of scrap plastic materiel similar to your bucket pan and dye it, coat and wait for it to cure, then spray some of the adhesive on it lightly to mimic the overspray and then try your different solvents and see which works without harming the rest of your hard work. It might take a week to dye and coat the scrap/sample but in the end it will be worth it.
Old Feb 25, 2017 | 05:11 AM
terrys6t8roadster's Avatar
terrys6t8roadster
3M adhesive remover. Just got some at Advance Auto. T
To Overspray clean up
