what does this actuator do....
Old Mar 1, 2017 | 03:48 AM
Dave Vincec's Avatar
Dave Vincec
Default what does this actuator do....
Hi All,
Had wiper door mechanism out to repair a sheared actuator linkage (long story!); and came across an actuator that a) I didnt know was there.... and b) can't seem to find in the '68 AIM..
Under the passenger side fender in the wiper door well? many thanks for clarification!
Dave
Old Mar 1, 2017 | 04:17 AM
F4Gary's Avatar
F4Gary
2018 C3 of Year Finalist
2016 C3 of the Year Finalist
That door closes when you put your a/c on Max.
Old Mar 1, 2017 | 04:23 AM
Dave Vincec
ahh... so it WAS an A/C car.... i thought it might have been, but the system has been completely gutted... (The firewall was blocked up with a baking tray and a few wood screws )
i'm trying to get the components together to reinstate the heater; but it seems 68 parts don't grow on trees anymore...
Thanks!
Old Mar 1, 2017 | 04:45 AM
F4Gary's Avatar
F4Gary
A/C cars also didn't have the two vent levers on either side of the console.
The pictured actuator closes a door, and another actuator opens the door down by the passengers right foot in that kickpanel.
Old Mar 1, 2017 | 04:55 AM
Dave Vincec
the '68 console plate was also taken at some point... when i bought it, it had a 72-76 plate 'sort of' stuck where it should have been
I've now got a '68 plate, and the correct levers/frame - I just havnt got to the interior yet!
given that it has the actuators at the moment; do you know if i need anything else other than the cables to convert it back to standard cable actuation if i remove the actuators?
Old Mar 1, 2017 | 05:06 AM
F4Gary's Avatar
F4Gary
It was all vacuum operated. The only cable I have is from the Temp wheel to the mixing door. Mine is a '72.
Old Mar 1, 2017 | 05:14 AM
Dave Vincec
This one is a '68 - and as i'm discovering... there were lots of 'one year' parts that are now difficult to get hold of!
The A/C cars ran vacuum everything, like the later cars - but the non A/C cars were cable operated... it seems that I have an A/C car - that I am trying to convert to a non A/C car because a) getting an A/C system would be even more painful than getting a heater... b) i don't think i'd have a rabbits chance at a greyhound track in getting it to fit (big block with awkwardly shaped headers) and c) it wouldnt get much use here in the UK; where the weather is routinely terrible!
Old Mar 1, 2017 | 06:46 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by Dave Vincec
...do you know if i need anything else other than the cables to convert it back to standard cable actuation if i remove the actuators?...
Do you have the 68 AIM? The AIM shows the AC installation and, in this case, what is not on your car.
Left side vents are blocks off and not used for AC cars, so you won't need to attempt to run a left side vent cable. For the right side, you will want to replace the kick panel vacuum actuator and hardware to fit a cable.
Old Mar 1, 2017 | 07:09 AM
Alan 71's Avatar
Alan 71
Hi DV,
Here's the kick panel vent plenum opening, door, bowden cable and it's bracket on the right side of a 71 non a/c car.
The are spring-loaded 'pins' on the top and bottom of the door that allow the cable to pivot the door open and closed.
The configuration is about the same for the left side.
Regards,
Alan
To what does this actuator do....
