C3 Won't start
Old Mar 17, 2017 | 01:58 PM
frankenbro's Avatar
frankenbro
Default C3 Won't start
My 82 Collectors Edition runs great until you shut it off then it won't start for about 20 Minutes. Is it a heat sensor someplace?
Old Mar 17, 2017 | 02:55 PM
Staylor63's Avatar
Staylor63
It could be the starter getting too hot....they make a heat shield for that.
Old Mar 17, 2017 | 03:12 PM
dmaxx3500's Avatar
dmaxx3500
does it still turn over and not run or does the key do nothing?
Old Mar 17, 2017 | 04:30 PM
Knerf's Avatar
Knerf
also check your battery cables if its not turning over when warm.
Old Mar 17, 2017 | 04:51 PM
frankenbro's Avatar
frankenbro
Absolutely nothing, the first time I called AAA for a jump which probably worked because they took so long to respond. Two more times I called my son only to have him show up just as it finally turns over and starts. That's when I realized all I had to do was wait about 20 minutes.
Old Mar 18, 2017 | 12:55 PM
MelWff's Avatar
MelWff
double post
https://www.corvetteforum.com/forums...n-t-start.html
Old Jun 23, 2017 | 10:57 AM
frankenbro's Avatar
frankenbro
Thanks everyone for the help. I put a new battery in and it seems to have solved the problem. When the weather gets hot I'll know for sure.
Old Jun 23, 2017 | 11:00 AM
frankenbro's Avatar
frankenbro
Default C3 won't start
Thanks everyone for the help. I put a new battery in and it seems to have solved the problem. I'll know for sure when the weather gets hotter.
To C3 Won't start
