Cleaning Up Battery Corrosion?
Old Mar 20, 2017 | 03:26 PM
Bergerboy's Avatar
Bergerboy
Default Cleaning Up Battery Corrosion?
Hi Experts.
Looking for some good advice for cleaning out all the corrosion from the battery tub in my '69 coupe.
I've bought new brackets and rivets and plan to install them in the next week or two, but there is so much acidic corrosion in the area around the front and rear brackets, that I can't even tell what/if there's any hardware in place at all.
The battery has been living in the tub semi-loose with only a hunk of 2x4 in front and rear of the battery to keep it from knocking around while driving.
What's the best method (and chemical) to remove the corrosion from the bottom of the tub, just to see if I have any brackets/rivets remaining to remove?
I'd really like to take it down to the base fiberglass, and build up from scratch with the new hardware.
Thanks!
Old Mar 20, 2017 | 03:45 PM
MelWff's Avatar
MelWff
use an equal amount of baking soda and water paste and apply to the corrosion. Let it sit for awhile and then rinse.
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by Bergerboy
...What's the best method (and chemical) to remove the corrosion from the bottom of the tub...
Baking soda and water and an old toothbrush. Mix the baking soda and water. Pour it on the crud. Let it sit a while. Take the toothbrush to it.
Old Mar 20, 2017 | 03:56 PM
ENCSDOUG's Avatar
ENCSDOUG
Then after it dries and you tighten down the cable lugs, apply some dielectric grease to protect your lugs from corrosion.
Old Mar 20, 2017 | 05:38 PM
TimAT's Avatar
TimAT
Pull the cables out or any plugs that may be in the bottom of the tub. Scrub as above and rinse with water. Let it dry. Unless you're concerned about originality, you could drill a couple of holes for drains and them put plugs in them.
To Cleaning Up Battery Corrosion?
