Hardtop pad / clear vinyl ????
Old Mar 20, 2017 | 05:59 PM
fotyfobravo's Avatar
fotyfobravo
From: Lake Arrowhead - Georgia > 72 Base Coupe & 74 BB Roadster
Default Hardtop pad / clear vinyl ????
In the past I have seen a "self sticking" clear plastic protector that gives additional protection to the rear deck lid from the hardtop.
I can't find one anywhere. Anyone remember these or know of them?
Old Mar 20, 2017 | 06:09 PM
JBrooke825's Avatar
JBrooke825
2018 C3 of Year Finalist
All of the suppliers have them but they do show ,a lot.
Old Mar 20, 2017 | 06:13 PM
fotyfobravo
I called Ecklers today, they said they didn't have it. I will keep looking.
Old Mar 20, 2017 | 06:45 PM
Paul L's Avatar
Paul L
http://www.parts123.com/corvettecent...50g&ukey=11765
Old Mar 20, 2017 | 07:20 PM
fotyfobravo
That's IT! Thank you!
Old Mar 20, 2017 | 07:48 PM
Paul L's Avatar
Paul L
I have both the black and clear versions. I tend to use the black for no particular reason.
Old Mar 20, 2017 | 10:49 PM
redrdstr72's Avatar
redrdstr72
They don't have to show.
Whether you're working with the soft top or the hard top, you can install so that the insulator is almost invisible from the outside.
Here's how:
Position the top and mark the outside edge plus 1/4"-3/8" margin with blue painter's tape. Raise/remove the top and locate the insulator, using the tape as stop/guide. Wet the surface before placing insulator and squeegy excess water out, using a credit card. Locate the top to see that only a minimal amount of the insulator is visible.
Because I have both tops and use them both, I found it problematic to be doing this so often. I ended up removing the deck lid and taking it to have the "invisible" 3M film that's used on facias, etc on the entire lid. Now I have permanent, invisible protection, regardless of which top is on the car. The film can be removed at any time if I so choose. In my mind, this is the perfect solution. Not cheap but very effective.
Hope this helps.
To Hardtop pad / clear vinyl ????
