I just reinstalled my rear 9 leaf spring that is used and new hangers (poly) and put in brand new ac delco shocks. The front suspension it good but the rear doesn't move with 2 guys bouncing on the frame... is this right? Or is there something wrong?
I believe that is normal. The reason is the single spring for both rear wheels. When you push down on the body at the rear your force spreads to both sides and you are deflecting the entire spring. When a single rear wheel rolls into or over something it deflects only its' half of the spring. With separate coil springs at the front it's easy to push down on the body such that only one of the springs resists most of the force. I hope that makes sense.
Do the math - two 180 guys jumping on a (say) 360#/ inch (each side I assume) won't deflect a spring very much. I just lowered my entire car on the rear spring. At say 1600#'s entire deflection was 1". So expect maybe 1/4" deflection at most.
Hi yvh,
Here's an example of the rear suspension on a complete chassis with running gear in place, but no body.
How does this spring's arch compare to what you're seeing on your chassis?
Regards,
Alan
Hi yvh,
The fuel supply elbow in the sending unit shouldn't turn at all.
The rear spring is a replacement spring of some sort.
It's difficult to guess what the ride height will be without knowing this spring's specifications.
The two shipping bands should be removed.
The four bolts that hold the spring in place should not be torqued until the body is in place and ALL of the car's weight is on the spring.
Note arrows:
Why this difference?
Something bent? Frame rail twisted?
Regards,
Alan
Hi yvh,
Note arrows:
Regards,
Alan
jez thanks for pointing that out... I'll be looking into that tonight as well as ordering a sending unit
Hi yvh,
Rear springs that were used for standard production and those used as part of suspension options are well known.
They have certain physical configurations that often make them readily identifiable. Aftermarket springs lack these configurations.
After market springs are often designed to be part of a performance suspension and thus have different specifications that change their deflection rates from those of the springs used in production.
Regards,
Alan
Hi yvh,
Regards,
Alan
I figured out why that crosmember under the gas tank was crooked. It has spacers on one side. I'll take them out tonight.
