Help identifying this engine?
Old Mar 25, 2017 | 02:16 PM
bradsnw's Avatar
bradsnw
Default Help identifying this engine?
It's installed in a 1974 C3 coupe...
Engine casting: 3970014
Casting date: E24 73
Engine ID: T0602CKW
Partial VIN: 13L229592
Thinking this engine block was never in a corvette.
Thanks,
Old Mar 25, 2017 | 02:30 PM
Nowhere Man's Avatar
Nowhere Man
2015 C2 of Year Finalist
1973 350/145 2 barrel carb, auto from a Camaro or Nova built in Van Nuys Assembly
Alan 71's Avatar
Alan 71
Hi b,
The CKW broadcast code was used 3 times.
72 Corvette 200hp, 4-speed
73 Camaro and Nova 145 hp, automatic
76 Corvette 180 hp, 4-speed.
The block casting number was used interchangeably with the more common 010 block. I believe it began to be seen in Corvettes during 72 model year production.
Regards,
Alan
I believe the 014 block was cast at Tonawanda not Flint.
Old Mar 25, 2017 | 02:40 PM
joewill's Avatar
joewill
my book says...
73 nova 350. automatic TH350 145 horsepower built june 6 1973, block casting may 24, 1973.
its in a corvette now? so never say never!
bradsnw's Avatar
bradsnw
Thanks for the quick replies. The C3 it's installed in is a 4 speed manual. Could it be this was the 72 Corvette engine block?
Old Mar 25, 2017 | 02:45 PM
bradsnw's Avatar
bradsnw
1Z37J4S411831 is the car VIN.
Where can you find the code for the original paint and interior options?
Many thanks,
Old Mar 25, 2017 | 02:56 PM
Nowhere Man
On the drivers side door jam by the dash there is a metal tag commonly referred to the trim tag. On the tag is the exterior and interior colors. Post them up
Old Mar 25, 2017 | 03:04 PM
bradsnw's Avatar
bradsnw
Trim: 408
Paint: 74L
Old Mar 25, 2017 | 03:07 PM
Nowhere Man
paint code 74 is Medium Red trim 408 is Neutral vinyl
To Help identifying this engine?
