parts washer
Old Mar 26, 2017 | 01:00 PM
ESU's Avatar
ESU
Default parts washer
Anyone using a parts washer in their garage or shop? Was looking to pick one up from harbor freight but they couldn't recommend what cleaner to use. What are you guys running in your washer? Mine will be in my basement so hopefully something that's not to "pungent"....
Old Mar 26, 2017 | 01:19 PM
oemtech's Avatar
oemtech
Veteran: National Guard
Do not under any circumstances put your parts cleaner in your basement. I would venture to say that 80% to 90% of the parts cleaner is solvent based and flammable.
Most auto parts stores have parts cleaner in in 5 gal cans... Tractor Supply also carries it. I have used Kerosene in a pinch.
Lastly you will need a place to dispose of the used solvent.
Old Mar 26, 2017 | 01:30 PM
Mako72's Avatar
Mako72
2018 C3 of Year Finalist
Having tried the nonflamable fluid, I returned to using mineral spirits available in 5-gal jugs at paint stores. The nonflamable fluid just wouldn't cut the grease fast enough or as good as mineral spirits.
Old Mar 26, 2017 | 02:16 PM
redvetracr's Avatar
redvetracr
mineral spirits aka paint thinner from Sunnyside (white plastic bottle) is what I use, you might also consider a small fan to blow the fumes away while you work so your not breathing in solvent
Old Mar 26, 2017 | 05:22 PM
Tiger Joe's Avatar
Tiger Joe
I use a product called "oil eater" made by Kafko. Can buy it on amazon it's like $10/gal. Dilute with water. A 5 gal bucket is enough to fill my 30 gal cleaner
It is non flammable and it works just fine for everything I have used it on. Has no odor.
And yes I have used kerosene, thinner, diesel, you name it.
Old Mar 26, 2017 | 05:38 PM
Mr D.'s Avatar
Mr D.
My parts washer story; found a professional parts washer on Craigslist local for $150 that sells new for around $1500. Got it home and cleaned up and just needed some solvent. Took 30 Gal of Crown PSC 1000 at $40 per 5 Gal can at Tractor Supply.
Cost me $200 in solvent for that $150 parts cleaner. But it is a kick *** parts washer.
Old Mar 26, 2017 | 11:01 PM
Tim 1973's Avatar
Tim 1973
My parts washer came from tractor supply, I change the solvent every 3 years at a cost of 160.00 I would not be with out it but it is flammable and I keep the cover closed when not using it. I also have a fire extinguishers all over my shop that's a metal building.
Old Mar 27, 2017 | 12:13 AM
nwav8tor's Avatar
nwav8tor
Old Fart Pilot
Make sure you check the data/specs for the HF parts washers. I think they might only be for use with water based cleaner fluid!
Old Mar 27, 2017 | 12:37 AM
Duntov's Avatar
Duntov
I have the small Harbor Freight one and bought some safety kleen solvent from a shop for a few bucks. It cuts the grease fairly well, but didn't like that it didn't have a brush that had solvent running through it. I bouts a slip on one that went over the nozzle and works great.
Old Mar 27, 2017 | 09:23 AM
ESU's Avatar
ESU
I was curious about the brush part, would like a brush, guess I can do the same. How much fluid does it hold? The specs didn't say.
Old Mar 27, 2017 | 09:24 AM
ESU's Avatar
ESU
Yes Ive heard that as well.
Old Mar 27, 2017 | 09:25 AM
ESU's Avatar
ESU
Understood, just really don't have the room in my garage, HF makes a small countertop type that I was interested in.
Old Mar 27, 2017 | 09:27 AM
ESU's Avatar
ESU
Shouldn't be an issue indoors then?
Old Mar 27, 2017 | 09:30 AM
ESU's Avatar
ESU
If anyone has an alternative, relatively inexpensive parts washer unit they use as opposed the HF I'd like to hear about it. The HF portable one is like 50 bux and the model with its own cart is like 100.
Old Mar 27, 2017 | 10:02 AM
Mr D.'s Avatar
Mr D.
5 Gal Home Depot Bucket
Old Mar 27, 2017 | 12:12 PM
Duntov's Avatar
Duntov
Mine is either 2.5 or 3.5 gallon unit. Had it for a while but only recently put it to use. The brush attachment makes nicer.
Old Mar 27, 2017 | 01:38 PM
ESU's Avatar
ESU
Just found this one, a bit more than I wanted to spend but it looks really portable, check out the gasket on the lid, looks like it seals up tight, and has a Brush for me and Duntov.
Amazon Amazon
To parts washer
Old Mar 27, 2017 | 02:00 PM
cv67's Avatar
cv67
St. Jude Donor '05
Cheap hack one here ya go!!
Home Depot;bought a small fountain pump less than $30
Few gallons of purple power, simple green etc
Put pump in bottom of 30 gal kitchen type trash can
Drop part it and walk away
I added piping hot water to it, hey it works.
Those brushes for most those cleaners are pure junk
Old Mar 28, 2017 | 03:42 PM
jcloving's Avatar
jcloving
I have a HF stand up parts cleaner. I bought it used and 20gal of solvent came with it. It works well.
Yes, get a fan. I use mine in my garage and have the garage door open too.
Good Luck
Old Apr 20, 2017 | 03:49 PM
ESU's Avatar
ESU
Just an update, bought the OEM tools one off Amazon, bigger than I thought. Lid seals up tight with 2 snap locks, has built in brush etc. I tried the krudcutter and oil eater, both water based and quite frankly they both left a lot to be desired. Then again I was working on some old forearms parts with cosmoline. Will move on to the next item, maybe purple power and see how that works... And this pump also says water based only.
