Changing defroster cable
Old Apr 2, 2017 | 05:35 PM
Tiger Joe's Avatar
Tiger Joe
Default Changing defroster cable
68 non A/C car
Need to change the cable that controls where the air is directed.
I had the lower console apart to change one of my Astro ventilation cables and see this cable is broken.
Looking at diagrams it appears the air flapper is directly behind the gauges. Is this right?
I doubt there is any way to reach it from the side, gauges have to be pulled I'm guessing?
Old Apr 2, 2017 | 06:08 PM
bazza77's Avatar
bazza77
not sure of any difference between 68 and 69 but my cable snakes along the bottom of the box for most of the way to the passenger side end , so access should be from passenger side . Put your hand up under there and feel for the lever first , might even be able to see it if your a contortionist.
P.S I'm talking about the blend door ! controlled by the wheel !
If your talking about the cool air ducts , they are behind the kick panels (two little square **** on edge of console plate controls them ?
Last edited by bazza77; Apr 2, 2017 at 06:13 PM. Reason: Blend door or just cold air ?
Old Apr 2, 2017 | 08:31 PM
Tiger Joe's Avatar
Tiger Joe
I'm talking bout the blend door.
Said I just changed the Astro ventilation cable in my first post
Old Apr 3, 2017 | 08:36 AM
Alan 71's Avatar
Alan 71
Hi,
"Need to change the cable that controls where the air is directed.
I had the lower console apart to change one of my Astro ventilation cables and see this cable is broken. "
I believe this info is good for 68 cars too:
I believe the 'temperature' of the air is controlled by the right thumb wheel and a bowden cable.
I believe the 'direction' of the flow of air is controlled by the left thumb wheel, a vacuum manifold, and a hose to a vacuum pot on the left END of the air box. Another hose runs to a vacuum pot on the TOP of the air box.
There should be a total of 3 bowden cables, one for the air temperature control, and two for the kick panel vents.
Regards,
Alan
Here's the vacuum pot on the TOP of the air box, the other is similar. You cab also see the black bowden cable headed to the air temp door in the air box.
Old Apr 3, 2017 | 09:02 AM
Tiger Joe's Avatar
Tiger Joe
Alan, there is no vacuum on a non A/C car.
my direction of airflow is controlled by a cable
Old Apr 3, 2017 | 09:10 AM
Alan 71's Avatar
Alan 71
Hi TJ,
Thanks.
That's why I had the note about the info applying to 68? cars.
By 71, (maybe earlier), non a/c cars had vacuum operated control functions for the air flow direction.
Regards,
Alan
Old Apr 3, 2017 | 10:12 AM
bazza77's Avatar
bazza77
Originally Posted by Alan 71
Hi TJ,
Thanks.
Regards,
Alan
69 had vacuum operated control, mine is 22 920 no A/C so its not early 69 if it matters
Old Apr 18, 2017 | 11:40 AM
Tiger Joe's Avatar
Tiger Joe
just to close this in case anyone is ever looking for information
The cable operated blend door on the 68 is directly behind the gauges and there is no way to access it without removing them, not matter how hard you try to twist your arm up there!
Old Apr 18, 2017 | 01:03 PM
TimAT's Avatar
TimAT
My 69 is a Nov 68 build- and there is vacuum control.
To Changing defroster cable
