question about speedo driven gears
Old Apr 3, 2017 | 02:24 PM
jteagle's Avatar
jteagle
4th Gear
Default question about speedo driven gears
I have a 1978 vette that I recently purchased. The speedo is about 10 miles per hour slow. My tire size is 255/60/15s and my rear gear ratio is supposed to be 3.73. What spedo gear would I need to correct the speedometer?
Old Apr 3, 2017 | 03:55 PM
joewill's Avatar
joewill
if your speedo is too slow, then the cable is spinning too slow, you need to speed it up by replacing your driven gear in your transmission by a smaller one, one with less teeth. pull out your original from your tranny.
they are pretty cheap. you can buy them from parts vendors..get 2, one with 1 less teeth, and the second with 2 less teeth... then trial and error using your phone's gps speedometer app.
this is what they look like:
http://www.ebay.com/itm/like/1520521...&ul_noapp=true
Old Apr 3, 2017 | 06:28 PM
BKarol's Avatar
BKarol
This chart from Willcox gives the teeth count:
Old Apr 3, 2017 | 07:30 PM
SHARKBIT77's Avatar
SHARKBIT77
Ive generally found a 1 tooth change moves the speedo about 4 MPH at 55.
Old Apr 3, 2017 | 08:25 PM
doorgunner's Avatar
doorgunner
2026 Loser of the Year
Also try to SEE the color of the drive gear that is inside your transmission. The drive gear and driven gear need to correspond in the chart to prevent damaging each other.
Old Apr 4, 2017 | 11:07 AM
jteagle's Avatar
jteagle
4th Gear
Default speedo gears
Originally Posted by joewill
is your speedo is too slow, then the cable is spinnging too slow, you need to speed it up by replacing your driven gear in your transmission by a smaller one, one with less teeth. pull out your original from your tranny.
I knew I needed to go smaller, just didn't know how many teeth to go.
Old Apr 4, 2017 | 11:09 AM
jteagle's Avatar
jteagle
4th Gear
Knew I needed to go smaller, just didn't know how many teeth to go.
jteagle's Avatar
jteagle
4th Gear
To question about speedo driven gears
