Champion Radiator fit into 69 with 350
I have a '69 with 350/350 and manual. Bought a Champion CC1655 and the passenger side lower outlet on the rad interferes with the frame. I see diff pics of rubber mounts that need to be squared off but mine do not look like that, mine are just u-shaped. Question is how do I get it to fit? Do I need to buy the other rubber mounts and square them off? Will those hold it up above the frame? Anyone else install a Champion CC1655? Advice? I will post pics shortly.
the lower rad tube is hitting both the u-shaped radiator support and the frame bracket for sway bar.
drivers side, u bracket provides no support.
shroud bracket hitting tube.
the old rad lower tube is higher up and the reason I changed it was the upper tube was pointing down and the hose was hitting the alt belt. Not the correct radiator, in my opinion.
