Help,Think I'm missing a frame bracket?
Old Apr 5, 2017 | 09:47 PM
R75R's Avatar
R75R
Cruising
Default Help,Think I'm missing a frame bracket?
When I found my car it was in a field and the motor and transmission were already removed from the car. My question is , Should there be a transmission mount of some kind on the crossmember with the two exhaust holes are? If so where do I find one? What am I looking for? Thanks for the help.
Old Apr 6, 2017 | 01:08 AM
KapsSA's Avatar
KapsSA
Active Streak: 90 Days
I believe the turbo400 just mounted to the crossmember through those 2 holes but I'm probably wrong.
That IS an automatic crossmember(bolt on).
I know 350 or manual you need something like this.....
http://www.ebay.com/itm/1968-76-Corv...RXFsja&vxp=mtr
I don't see the mounting "ears" on your crossmember, tho.
Old Apr 6, 2017 | 06:55 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by R75R
...Should there be a transmission mount of some kind on the crossmember with the two exhaust holes are?...
Yes. There will also be an exhaust hanger when the time comes.
...If so where do I find one?...
It might still be on the tranny. If not, Corvette parts vendors have them.
...What am I looking for?...
Transmission mount.
FWIW: the AIM shows all this and lists the original GM part numbers for what you need.
Old Apr 6, 2017 | 07:00 AM
bazza77's Avatar
bazza77
heres the ears ,
http://www.zip-corvette.com/68-82-c3...kets-ears.html
heres the TH400 mount,
http://www.zip-corvette.com/68-77-tu...ion-mount.html
Old Apr 6, 2017 | 08:19 AM
Alan 71's Avatar
Alan 71
Hi r,
"in a field" !!!!! You are a hero!
Here's a photo showing the 4-speed transmission crossmember, the transmission mount bracket, the rear transmission mount (thick rubber), and the bracket for mounting the exhaust.
While this is a 4-speed car, the parts for a automatic car are somewhat similar.
On an automatic car the rubber transmission mount bolts directly to the crossmember, but a exhaust mounting bracket is still used, along with a small french lock.
Good Luck!!
Regards,
Alan
Old Apr 6, 2017 | 08:28 AM
Mr D.'s Avatar
Mr D.
Harbor Freight sells jack stands (2) for $21.99
Old Apr 6, 2017 | 02:10 PM
KapsSA's Avatar
KapsSA
I should have mentioned the rubber mount but thought he was referring to the metal extension like shown in Alan71s pic.
Old Apr 6, 2017 | 10:22 PM
R75R's Avatar
R75R
Cruising
Thanks for all the response, I do have the original TH400 that belongs to the car. Looks likes I need a rubber tranny mount. Also Mr.D I have plenty of jack stands, the tires are actually sitting on roll around Dolly's so I can move the frame around my shop. Here is the resting spot where I rescued my car from.
Old Apr 6, 2017 | 10:58 PM
radiotexas's Avatar
radiotexas
R75R
You deserve a medal for rescuing that Corvette. And we all thank you for doing it. Glad it's a dry OK car. Please keep a photo diary of your efforts.
PS can you take it easy on the Longhorns for a couple of years? Thanks
Tex
To Help,Think I'm missing a frame bracket?
