Speedometer Gear
Old Apr 8, 2017 | 03:13 AM
mrichi's Avatar
mrichi
Default Speedometer Gear
I installed a TKO 500 transmission in my 79 Vette only problem is the speedometer is reading 20mph faster than my gps reads. I have the yellow speedometer gear if I went to a larger gear would that fix the speedometer error
Old Apr 8, 2017 | 10:02 AM
footloose42's Avatar
footloose42
I believe that would fix the problem, yes. There are different speedo gears with different numbers of gear teeth depending on your transmission.
