Turn signal issue after column work
Old Apr 8, 2017 | 09:44 PM
vmsns007's Avatar
vmsns007
Default Turn signal issue after column work
So I took my 74 standard column out to replace a broken turn signal switch. Column is back in car.
Ignition working fine.
Brake lights working.
Reverse lights working.
Tail/running lights working.
The turn signal lever operates fine now but here is my symptom:
- right front turn signal blinks when I turn lever up(right) but rear turn signal doesn't blink
- left turn signals not working (front or rear)
I thought maybe a fuse might be bad but if that were true the front right wouldn't work I would think (I haven't yet pulled the directional fuse)
Suggestions where I should start ?
The turn signal switch and ribbon cable are new and securely snapped into harmonica
Old Apr 8, 2017 | 10:14 PM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
I'd go to the connector on the turn signal switch first and make sure this is plugged in good and tight. That's where I'd start for sure.
