FINALLY! My '69 vert
Pulled the battery out to clean that compartment and didn't like the look of the cables. I pulled the negative one out, since it's easiest to reach.
Cables were cut, I assume to install new terminal clamps, and spliced using a piece of crimped copper pipe to make the connections. To be fair, it was well wrapped with electrical tape.
What type of terminal clamps were in use in 1969? Top post or side post?
I fixed the negative battery cable. Got some NAPA 2 gauge wire and built a new cable. At some point I'll do the same to the positive cable, but due to it's location and routing, I'll leave that for another day when I'm feeling particularly frisky.
I've been working on the seat belts and found a ridiculous "Bubba" fix, where someone added an extension to the lap belt using some sheet metal and an anchor bolt that wasn't even the right size to thread properly!
I removed the extension belt and properly secured the seat belt. Next I'll be adding shoulder belts. Tonight I verified that the factory did install the shoulder belt mounting brackets in 69 verts.
My '75 coupe that I'm getting ready to sell generously donated it's white letter BFG radials to the 69. Took both sets of rims down to Costco and had them swap the tires. The 69 had BFG's, but they were smaller black walls and were directional.
Installed my new chin spoiler (thank you, Willcox).
And lastly, learned more about differences between year models of these chrome bumper cars. Can you pick out the difference between these two bezels? Which is original?
RVZIO
No idea why they'd change the location of the lower nozzle?
No headlight squirters on the 75. This feature was 69 through early 71, from what I can find.
I'm also working on a power brake conversion. First step, drain the master cylinder. A syringe and some latex tubing made this mess-free.
Looks like a fluid change is way overdue.
Break the lines loose from the master cylinder, then remove them from the proportioning block.
This part required some line wrenches, which I didn't have, so I ran up to Home Depot and bought a set.
Remove the two nuts holding on the master cylinder and pull it off. The studs it was bolted to get knocked out and fall into the driver's floorboard. The two lower bolts get removed.
Next step is to use the gasket for the power booster to mark where new upper holes need to be drilled, as well as where to open up the large center hole. I used a hole saw and a utility knife.
Test fitting the new power booster. I had to remove the oil dipstick and bend it a little to get it to clear the booster.
More to come!
RVZIO
RVZIO
Speaking of gaskets, or technically grommets I guess, I found I'm missing some. You can see to the right of the power booster in the last pic that there's no grommet for the speedo cable. I noticed another one missing on the other side somewhere when I was bent up like a pretzel under the dash, getting the clevis attached to the brake pedal.
Rick
RVZIO
I cheated and used black silicone sealer where anything came through the firewall.....at night with a bright light under the dash the firewall looked like swiss cheese. Fuse block was just as bad......
It wasn't in horrible shape, but it needed some attention. I pulled everything out of there and started cleaning. First, with some baking soda water in the battery area to take care of any battery acid that might be present. Then I followed up with more standard cleaners, followed by a good rinse and dry.
Here's the before shot.
I had picked up a can of spray in bed liner that I wanted to use for the compartment.
Here are the after shots.
I was pretty pleased with the results. The stuff sprays much like any spray paint. I was worried it would be too thin, so I used up most of the can. Got a few runs, but due to the location, I wasn't too worried about that.
It has a rough, grainy texture, just like you'd expect from bed liner material. I like it, for this particular application.
Back to the power brakes tomorrow.
Got the new master cylinder installed, along with the new lines to the proportioning block. Bled the M.C., then bled all four calipers.
Got everything buttoned up and took her out for a test drive. Night and day difference! She stops when I tell her to now. Before, it felt like I'd need to do a Fred Flintstone and put the pedal through the floor to get stopped. Not that the manual brakes didn't work, and the pedal was firm, but they sure didn't feel safe. Loving the change!
Here's a pic after getting back home. Another safety item I addressed can be seen on the passenger door. I have no idea why they didn't put a mirror on there to begin with. Maybe it's my O.C.D., but having just the driver's mirror makes the car look lopsided.
And since I still had a couple hours of light left, I got started on the next project on the (ever growing) list! Ever feel like you've opened a can of worms?
But I did get all the carpet fitted in the rear area. I took it slow...I had visions of cutting too much off of one piece of carpet and then having to buy another set.
The two wheel well pieces were the most work. I'd get a piece laid in, measure, remove, trim, rinse and repeat about a hundred times. In the end, it fit nicely and didn't need any adhesive, with the exception of one area where I used a piece of double sided gorilla tape.
Here's the finished product. Tomorrow, hopefully, I'll be able to knock out the front pieces.
Attachment 48345095
