Driver's window
Old Apr 12, 2017 | 03:32 PM
FredFitz's Avatar
FredFitz
7th Gear
Default Driver's window
The driver's side window on my '79 was jammed. I manage to get to move but it won't move freely. The only way I can get it to go all the way up is to pull on it while I hold the switch.
Old Apr 12, 2017 | 04:01 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Have you lubed the channels?
Old Apr 12, 2017 | 04:52 PM
SwampeastMike's Avatar
SwampeastMike
Does the window go down much faster than it goes up? If so the assist spring is broken.
Old Apr 13, 2017 | 09:02 AM
gbvette62's Avatar
gbvette62
Motor could be tired and not have the oomph to lift the glass anymore. Motor or regulator gear, may be worn, and not making good contact. You're going to have to pull the door panel, and get into the door, to see what's happening.
To Driver's window
