Help - additional stamp over VIN block stamp
Old Apr 20, 2017 | 10:59 AM
glenny's Avatar
glenny
Default Help - additional stamp over VIN block stamp
On a '79 I'm buying, there is a stamp (Y38) over the visible VIN stamp on the block. The block VIN matches the the car's VIN and all the other numbers match and look legit. I'm just wondering if this extra stamp could be stamped at the time of an engine rebuild? Any opinions are appreciated. Thanks.
Old Apr 20, 2017 | 11:21 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Possibly. Was the engine rebuilt at some point in the past?
Old Apr 20, 2017 | 11:26 AM
MISTERZ06's Avatar
MISTERZ06
Originally Posted by glenny
On a '79 I'm buying, there is a stamp (R43 I believe) over the visible VIN stamp on the block. The block VIN matches the the car's VIN and all the other numbers match and look legit. I'm just wondering if this extra stamp could be stamped at the time of an engine rebuild? Any opinions are appreciated. Thanks.
PICS
........................................ .................. tom
Old Apr 20, 2017 | 11:40 AM
Alan 71's Avatar
Alan 71
Hi g,
Occasionally/often when an engine is rebuilt the engine block is 'decked'.
This machining may remove enough material from the top surfaces of the block that the original engine stamps are lost as a result
It sounds like in the case of the engine you're looking at the engine was rebuilt but the block wasn't decked.
If you're interested in 'originality' this is a 'good' thing!
Regards,
Alan
Old Apr 20, 2017 | 09:20 PM
glenny's Avatar
glenny
Thanks very much for everyone's' input. Ive concluded the motor was likely rebuilt and stamped at that time.
Old Apr 21, 2017 | 08:10 AM
Easy Mike's Avatar
Easy Mike
...Ive concluded the motor was likely rebuilt and stamped at that time...
Makes sense.
To Help - additional stamp over VIN block stamp
