Will these fit my 70
04-26-2017, 01:39 PM
Location: YANKEES UNIVERSE 70 454-LS5 500 ft-lbs Torque
04-26-2017, 01:53 PM
If they do fit, I can only imagine a ton of photos getting posted.
04-26-2017, 02:34 PM
Quote:
Originally Posted by
jr9170
Kumho 245/45 ZR17 and AR wheels off a 67[/img]
Measure the backspacing. If its 4" BS then they should fit.
The tire size is ok, but the wheel offset is the important measurement.
04-26-2017, 02:38 PM
Oh u can count on a ton Pics.
04-26-2017, 02:53 PM
Im running 255/45x17 on a 69 so the tires fit but as others stated you need to give us the numbers for the wheels, back spacing, offset, and width.
04-26-2017, 03:08 PM
04-26-2017, 04:13 PM
I know there are some on here with them on maybe they can post them.
04-26-2017, 10:49 PM
Tire size is OK but the wheels are probably only 7" wide if they are off a mid year. An eight inch is a real tough fit on a mid year. So even if the back space is good you may be giving up an inch of width.
04-26-2017, 11:29 PM
Off a 67 restomod Street Shop frame.
