Starter wire routing.
Old May 1, 2017 | 05:10 PM
540 vette's Avatar
540 vette
Default Starter wire routing.
72 Big Block. Any pics on how your starter wires are routed to the starter. What brackets and clips are needed.
Thanks.
Old May 1, 2017 | 05:30 PM
Alan 71's Avatar
Alan 71
Hi 540,
This is the wiring at a sb starter.
I believe the black 'bracket' on the bell housing bolt for the positive battery cable and the 'clip' on the starter solenoid for the ignition connections are used on bb applications too.
Also notice the black clip riveted the underbody near the 'toe board' which captures the ignition harness as it makes it's way to the solenoid.
Regards,
Alan
Old May 1, 2017 | 05:44 PM
540 vette's Avatar
540 vette
Alan how did I know you would come along with one of your helpful pictures. Thank you.
To Starter wire routing.
