Db levels
Old May 5, 2017 | 10:44 AM
upnorth's Avatar
upnorth
Default Db levels
Does anyone know what the db would be on a 1976 350 11.1 compression with headers and chambered exhaust ?
Old May 5, 2017 | 10:50 AM
henrikse's Avatar
henrikse
Default Db
Go to an electronics repair center or ask a tech if you know one. They will have a db meter (monitor and could tell you
Old May 5, 2017 | 10:55 AM
Gordonm's Avatar
Gordonm
Download an app on your phone or iPad it will be close enough
70L46Conv4Sp's Avatar
70L46Conv4Sp
I've heard of smartphone apps that have a db meter. It could be a simple download. You could also check CandD, R&T, etc. archives in 1976 for road test db readings for that setup.
Old May 5, 2017 | 10:56 AM
70L46Conv4Sp
Great minds think alike, Gordonm!!!
Old May 5, 2017 | 10:59 AM
MISTERZ06's Avatar
MISTERZ06
Exhaust Music
https://video.search.yahoo.com/yhs/s...d&action=click
........................................ tom
Old May 5, 2017 | 11:38 AM
Richard454's Avatar
Richard454
That depends on several factors-
The distance is the main factor- then there is the RPM at which it's measured and even the angle or centerline . Also used is the speed the vehicle is traveling or stationary and whether or not the site is soft ( out in the open ) or hard (between buildings).
So- what's the parameters? I'd check the local code.
OR- I have heard- drive around in Canada and they will measure it for you- for the price of a ticket!!!
To Db levels
