Is this a fiber-optic splice?
Old May 5, 2017 | 03:56 PM
redbarchetta74's Avatar
redbarchetta74
Default Is this a fiber-optic splice?
I just purchased a used FO cable via EB (late 1980's Cadillac Brougham OEM) to fix a single bad FO cable, and I'm concerned that the one that I purchased was spliced previously, but I want to get some other opinions. Here's a pic:
Does that looks like a splice? If not, what purpose would that serve? It's about 1.5 ft away from the sensor end.
Old May 5, 2017 | 04:01 PM
Alan 71's Avatar
Alan 71
Hi,
I'd say yes.
I think the fact that the stripe goes into that "collar" at one place but comes out at a different place is the indication.
If the cable was continuous the stripe would be in a straight line,
Regards,
Alan
Old May 5, 2017 | 04:04 PM
bigredbrad's Avatar
bigredbrad
From: Lincoln NE Riding and Driving Corvettes since 1967.
does light go in and come out of it?
Thats the #1 concern.
bigredbrad
Old May 5, 2017 | 04:12 PM
henrikse's Avatar
henrikse
Yes it is a splice and not very good one. I was a splicer and would not put my name on that one. When you use a fusion splicer it gives you a reading on how good the splice is. If it works and was cheap enough go for it.
Old May 5, 2017 | 05:23 PM
69Vett's Avatar
69Vett
Corvette of the Year Winner 2017
2016 C3 of Year Finalist
Bubba Splice, very poor.
at a minimum the cable's must meet squarely, and straight.
Old May 6, 2017 | 09:55 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by 69Vett
...at a minimum the cable's must meet squarely, and straight...
True, and you're still likely to lose light value through the slice.
To Is this a fiber-optic splice?
