EFI for my '79
Can I get a recommendation on what would work well with my '79 - L350, manual transmission. The easier to install the better.
Thx Paul
Thx
Thx Paul
the new systems are way better and cheaper than just a few years ago. I have an EZEfi 2.0 on my Cobra, somewhat modified stock LS3 injection on my 72 Vette and I just installed a Fitech on a forum members car. All systems work well. Do your homework and pick what is right for your driving.
http://www.fuelairspark.com/fas/ez-e...l-pump-kithtml
the new systems are way better and cheaper than just a few years ago. I have an EZEfi 2.0 on my Cobra, somewhat modified stock LS3 injection on my 72 Vette and I just installed a Fitech on a forum members car. All systems work well. Do your homework and pick what is right for your driving.http://www.fuelairspark.com/fas/ez-e...l-pump-kithtml
I agree on not going back to a carb. I sold off or gave away all my carb stuff. Not looking back. The FI is just so much nicer to drive.
Do you happen to have a URL to the 2.0? I can't seem to find it.
Here is a link
http://www.fuelairspark.com/fas/efi-...-injectionhtml
went DPFI L98 injection, mounted pump on frame rail wrapped with a rubber hose, and a hose clamp, using stock fuel lines for supply and return, obviously changed to HEI and put the speed density computer behind the map pocket on right side....junkyard computers that maybe harder to find today, so I have about 4-5 of them, and rotate them every so often....aftermarket chip that costs less then 100 bux these daze....
I removed the exhaust crossover flap crap, and welded in the O2 sensor bung on one of the flapper holes, and sealed the other one.....
put a K&N filter on the T-body and done, basically......
car went to 24 mph on freeway even with the muncie and 336 rear.....
and that was at 80 mph too on a trip to Florida and back......
I would think you can do the entire project for lots less than I paid, because the gear is older and more parts around today....and chip prices are less than 100 bux these daze....
I REALLY REALLY like my EZ-EFI 2.0.... it was better the first day I got it running than my 730 ECM was after burning chips for it for years. It was fun to learn to burn chips and program stuff for that 730 ecm, but I am a lot happier with the EZ-EFI 2.0.
I actually have the TPI retrofit kit to run my RamJet 350(since the RamJet 350 essentially ran the same sensors as 730 ECM TPI engines).
Take a look below at the throttle body kits :
https://www.summitracing.com/search/...tion%20Systems
There's not great aftermarket tank options for our 79s; no one cares about them because they know we're not going to pay the exorbiant "Corvette tax" when our cars just dont' have the value of the early C3s and C1s and C2s.
You want to think about whether you want a drop-in (and crazy expensive) option that require cutting a hole in your tank or you have to retrofit with a sending unit for our tanks - then you either deal with fuel starvation with a normal pickup tube or you get a hydramat -like wicking system that's appropriate for non-EFI designed fuel tanks.
Personally for longevity and noise and in-tank option was the only option for me. But then you still need to decide on return or returnless.
The fuel system options still suck for the late C3s and require a LOT of homework to have a REASONABLE expectation of getting it right the first time.
Adam
