72 wiring question
Old May 9, 2017 | 01:01 AM
D0wnunder73's Avatar
D0wnunder73
4th Gear
Default 72 wiring question
Hi fellow vette owners & lovers. I have 72 convertible manual with a 350. There is a black wire that exits the main wiring harness along the firewall. The wire in question leaves the main harness with a tan wire that goes to the carby solenoid, exits main harness located behind the distributor. Where does this black wire go? Does it go to the TCS switch on the transmission? Please help
Old May 9, 2017 | 07:01 AM
Alan 71's Avatar
Alan 71
Hi DOw,
The lead for the switch on the transmission is long (24" ?) and typically has an unusual 'button' connector.
It's pretty easy to check to see if the switch is connected.
Regards,
Alan
Old May 9, 2017 | 07:09 AM
D0wnunder73
4th Gear
Originally Posted by Alan 71
Hi DOw,
Regards,
Alan
Hi Alan,
Thanks for the reply, the problem is that when I recieved the car the black wire was broken near where it exits the main loom so there was no connector on the wire to be able to determine the connection type or what length it is. I will try and get a photo of where it leaves the loom.
Thanks again
Old May 9, 2017 | 07:41 AM
Alan 71's Avatar
Alan 71
Ho DOw,
The wire for the transmission switch exits the harness at the same point as the wires for the wiper motor and washer pump.
Regards,
Alan
To 72 wiring question
