My 68 Redline spare
Old May 16, 2017 | 11:52 AM
SIXTYTWO's Avatar
SIXTYTWO
Default My 68 Redline spare
I finally got some time and took down the spare on my 68. Per the build sheet the car came with the red line tires, I was surprised to find a new GoodYear Red line . I checked it over against the NCRS guide and it seems correct and has a period correct Good Year label on it. I'm not familiar with the date coding stamped in the side wall so can't tell if this is a repo or a period correct GoodYear that was purchased in the 69 to 70 time frame. Any thoughts on what it is?
Old May 16, 2017 | 12:28 PM
Tiger Joe's Avatar
Tiger Joe
i think that last pic is the date code.
i think the "LK" part means late 68 L=68 K= October
Rim look likes it was definitely mounted on the car at some point, so maybe somebody has to put the spare on an used it, then in 69 bought 5 new tires and threw a "new spare" back in?
Old May 16, 2017 | 01:10 PM
SIXTYTWO's Avatar
SIXTYTWO
[QUOTE=Tiger Joe;1594749989]i think that last pic is the date code.
Rim look likes it was definitely mounted on the car at some point, so maybe somebody has to put the spare on an used it, then in 69 bought 5 new tires and threw a "new spare" back in?[/QUOTE
Thanks ,
It's a pretty original car with only 37,000 miles. When I got it it had GoodYear Eagles on it. They looked great but were dated 1985 so I trashed them and installed repo red lines.
I agree, I don't think it's an assembly line tire but most likely part of the first replacement set. These tires were notorious for short life spans.
Old May 16, 2017 | 02:30 PM
jhudec's Avatar
jhudec
Definitely not a repop, as the tread pattern is correct. Not assembly line either as it would not have the label on it.
Very nice find though.
Old May 16, 2017 | 02:42 PM
Alan 71's Avatar
Alan 71
Hi ST,
I'm sorry I can't help with dating before 1970.
It does look like a nice tire!
While the wheel weights appear to be the MICRO brand, they're on the outside of the wheel which would indicate the wheel/tire were at least balanced after they left St.Louis.
To my eye that tire looks quite 'fresh' for a tire that might be close to 50 years old?!!?
Regards,
Alan
Old May 16, 2017 | 03:01 PM
SIXTYTWO's Avatar
SIXTYTWO
Originally Posted by Alan 71
Hi ST,
Regards,
Alan
Alan,
It didn't look that nice when I pulled it from the carrier, I had just finished cleaning it up.
Old May 16, 2017 | 03:33 PM
L-46man's Avatar
L-46man
This is virtually identical to the redline still on my 69.
However I think the tire date says 16th week (april) 1986....so it's a NOS, replacement.
Old May 16, 2017 | 03:49 PM
Alan 71's Avatar
Alan 71
Hi 62,
If you get a little wiff of the air at the valve stem you'll likely be able to tell if it's St.Louis air or not.
Again, that LOOKS like a nice old tire.
Regards,
Alan
Old May 16, 2017 | 04:29 PM
exposingtime's Avatar
exposingtime
2015 C3 of the Year Finalist
My guess is that the tire would not have a sticker if it was sold in bulk to GM.
To My 68 Redline spare
