Speedometer Cable Coupling
Old May 20, 2017 | 07:49 PM
Inca32x's Avatar
Inca32x
Default Speedometer Cable Coupling
Can any one tell me how the long and short inside speedometer cables connect to each other at the couplings. I know the outside cable connectors screw together but unsure how the inside go together?
Old May 20, 2017 | 09:37 PM
CA-Legal-Vette's Avatar
CA-Legal-Vette
Are you talking about at the back of the gauge? If so, you just push it in. There's a goofy looking wire loop that holds it in place.
Old May 20, 2017 | 09:46 PM
Inca32x's Avatar
Inca32x
I was referring to the 2 piece speedometer cables were they come together under the driver side floor. I known the cable housings come together by screwing the fittings together but how do the cables inside the housings get connected. This is a 75 convertible by the way.
Old May 21, 2017 | 11:38 AM
DonnieP73's Avatar
DonnieP73
The lower cable should have a male and female end. The male with the cable extended, to the transmission
and the female with the threaded end connects to the upper cable with the upper cable going into the
lower female end. The upper cable should have the snap-on end to the speedometer and the other end to the connection.
Don't have photo of lower cable, but have the connection end of the upper.
Donnie
Old May 21, 2017 | 05:55 PM
Inca32x's Avatar
Inca32x
Thanks that helps explain the connection.
To Speedometer Cable Coupling
