Thermostat fail safe
Old May 21, 2017 | 02:23 AM
tpfarm's Avatar
tpfarm
Default Thermostat fail safe
Hi all;
Installing a new radiator and would like to replace my stat with one that fails in the open position. I did a search and nothing came up . does anyone know of a particular brand that is reliable and where to purchase one. Trying to avoid the off shore parts. Thanks.
Car is '73 350
Old May 21, 2017 | 04:51 AM
donaldb1's Avatar
donaldb1
Default Fail Safe thermostats
Probably nothing but off-shore available. Oreilly has them in several ranges. They will lock open too soon. Get extra gaskets.
Old May 21, 2017 | 06:11 AM
Dynra Rockets's Avatar
Dynra Rockets
Thermostats normally fail closed due to the fact they are closed when the engine is cold (ironically my two dead thermostats in 36 years/21 cars, have both failed open).
I started drilling a small bypass hole in thermostats in the early 90s if it doesn't have one already from factory. Saw it on a Mazda I was working on at the time and thought it was a good idea. Google Images "thermostat bypass hole"
Old May 21, 2017 | 06:37 PM
DUB's Avatar
DUB
YEP..I drill a small hole in the thermostat also....and have been doing it long before it seems to be a common practice from some auto manufacturers.
I have had ONE of the 'fail safe' thermostats from O'Reillys fail and not do its job...so I do not use them any longer....that is why you have a temp gauge....to keep an eye on it.
DUB
Old May 22, 2017 | 03:34 PM
MelWff's Avatar
MelWff
use a Steward wide mouth thermostat
example http://www.jegs.com/i/Stewart-Compon...FYaFswodkKEAOQ
Old May 22, 2017 | 03:38 PM
John 65's Avatar
John 65
Save your $$$$$
I had one of those t-stats go bad on me last year. It was just like any other t-stat would fail.
Old May 22, 2017 | 04:11 PM
Mr D.'s Avatar
Mr D.
I cut the center out of my T-Stat
Old May 22, 2017 | 06:35 PM
DUB's Avatar
DUB
I can agree with that. As long as the end result is doing its job and the temps are not skyrocketing....it does not matter.
I have used what I have shown in the photo below in some unique applications and often times they may need to be changed from a 'summer time' set-up to a 'winter time' set-up due to the owner want the heater to put off good heat.
DUB
Old May 22, 2017 | 07:17 PM
Mod75's Avatar
Mod75
2024 C3 of the Year Winner - Modified
My dad showed me this a long time ago, right/wrong ? Cant say but it sure does make it easier to evacuate the air from the Vetts cooling system.
Old May 22, 2017 | 09:31 PM
Mr D.'s Avatar
Mr D.
DUB
This is a science project in the making, will post all my findings in another thread.
Old May 23, 2017 | 07:01 PM
DUB's Avatar
DUB
I have been doing it like this for so ling I can not remember when I started it and I have NEVER had an issue with the hole in the thermostat causing any problems. This DEFINITELY speeds up getting the air out of the system.
BOY do I know what you mean by that statement. If you can remember to do so...PM me a link to it ...just in case I miss it when you start that thread.
DUB
To Thermostat fail safe
