Rear main seal
But Yes, both ends of the seal need to be flush with cap and block
........................................ . tom
letting the ends protrude
trim ends flush
add dab silicon to ends of flush seals
above plus on machined surface of main cap
........................................ ....................... tom
I've done a couple of rear main seals on C-3s, over the years, and I've always offset them about 1/8'-3/16". I also dab a little RTV on the main cap, as shown in the picture in a previous post.
The trick, when offsetting the seal, is when you ease the main cap in place, have the bolts CLOSE BY, so after guiding the ends of the seals in place, you hold the main cap snugly in place with one hand, and install at least one of the bolts, with the other hand, so the cap doesn't drop out of place.
The easy part, with a C-3, is that the engine sits far back enough in the chassis, so the oil pan can be dropped without having to raise the engine from the engine mounts. With respect to pan gaskets, I don't know the part number off hand, but go with the Fel-Pro 1 piece gasket, with the steel inserts.
Also, while you're in there, (famous phrase!!) I'd recommend installing a Melling or Moroso oil pump driveshaft, the one with the steel retaining collar.
That might not be the best advice, but I'm not sure what else to say.
Photo #1 - shows where you would put silicone on the rear main cap machined surface - to insure no leaks
Photo #2 - the pointer is just pointing to the rear main cap installed and the grove where the rear oil pan gasket goes
Photo #3 - shows a removed rear main cap with a worn/bad rear main bearing - meaning you had better give a look at the crank for wear/groves
................................. tom
Clean the ends of the seal halves with a good solvent to eliminate all oils/greases before dabbing on the sealant. Also, put very little sealant on the seal ends; you don't want it to squish out onto the working area of the seal.
But, no main seal leak. I did go ahead and order that one-piece oil pan gasket...that sucker is thick. It came with the bolt kit including the four longer bolts. But my cork gasket is holding up nicely.
So what am I looking at in terms of getting at the tranny leak. I'm assuming its where the shaft enters the engine/flywheel.
If the leak is emanating from INSIDE the inspection cover, there is really nothing you can do for it short of a rebuild of the transmission. Can you replace JUST the input seal[s]? Yes. But, the seal in not the problem. The CAUSE of such a leak is the wearing out of the input bushing which allows too much side motion of the shaft...and THAT causes the seal to wear out. Change just the seal and 6 months later (or less) you end up with the same problem. PLUS, the internal seals and friction plates are probably getting well worn anyway, so you might as well just get it rebuilt and be done with it. (Or take that opportunity and swap it out for a rebuilt overdrive auto tranny!
)If the leak is running down the OUTSIDE of the inspection cover, it is likely coming from the trans pan gasket or some external seal in that area. Again, clean the area of ALL oil, drive the car some more, and find the REAL source of the leakage. Then you'll know what to fix.
