82 Corvette Fuel Problems
Old Jun 2, 2017 | 04:57 PM
Mickey Plymale's Avatar
Mickey Plymale
7th Gear
Default 82 Corvette Fuel Problems
My 82 has a new fuel pump, fuel sending unit, gas tank was cleaned out. Car seems to run fine until I reach about 1/2 tank, then if going uphill or sharp turn seems as though it wants to quit. Fuel guage seems to work because I checked the level when it reached 1/2 tank on guage and the tank appeared to be 1/2 full. If I fill the tank up it seems to run ok. Any ideas on what might be the issue? Thanks.
Old Jun 2, 2017 | 05:09 PM
terry82's Avatar
terry82
https://1982corvette.shutterfly.com/pictures/422#421 I would check the fuel line from the pump to the metal fuel line .I put on clamps.
Old Jun 2, 2017 | 08:54 PM
Mickey Plymale
7th Gear
Thanks. So apparently your fuel line to the metal fuel line was not secure? And the problem quit when you clamped it? I'll have to try that.
To 82 Corvette Fuel Problems
