Fuel problem ( fuel Pump )
Old Jun 4, 2017 | 01:46 AM
martys76's Avatar
martys76
Default Fuel problem ( fuel Pump )
350 sb car will bog out a 3500 rpm (almost die)
some times but act normal for days
die out again completely no fuel to carb
had it towed home and now starts
took line to fuel pump off and fuel runs out
took fuel filter out and the little white thing with the spring attached to it was displaced.
might this be a fuel pump problem never had heard of a fuel
pump being intermittent.
by the way it is still a mechanical fuel pump
any idea what my problem might be
Old Jun 4, 2017 | 08:18 AM
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
Your avatar says "martys76". Is your car a 1976 model? If so, have you checked the condition of the fuel lines, both rubber and steel, between the fuel tank and the fuel pump? Steel lines not all rusted, and rubber lines not soft and collapsing?
Old Jun 4, 2017 | 10:54 AM
henrikse's Avatar
henrikse
My thought is rubber fuel line. They go inside the line and collapse.
Old Jun 4, 2017 | 11:47 AM
CanadaGrant's Avatar
CanadaGrant
You say you took the fuel filter out and it had a little white thing with a spring attached. If you are talking about the inlet filter in the quadrajet and it has a ball with a spring behind it you have probably found your problem. Napa sells those anti drain back filters and they fail regularly. The ball causes a restriction and you run out of fuel as they stick and jam in the closed position. Use a normal filter that is open on one end with no ball and make sure the open end is at the fuel line inlet and not turned around. Below is one of the bad ones. You can see the ball is larger than the surround and jams up restricting fuel. Under load the carb literally runs out of fuel. If this is what you have, get one without the check ball or remove the ball and make sure the opening is facing the fuel line.
Old Jun 4, 2017 | 01:16 PM
martys76's Avatar
martys76
i put a new one and see what happens
gona make sure i have tools with me next time
Old Jun 4, 2017 | 06:03 PM
vincegward's Avatar
vincegward
Cruising
I had the same thing happen to my 77. The problem is the two rubber fuel lines from the fuel pump need replace.
To Fuel problem ( fuel Pump )
