I need to replace the 8 rocker panel weld nuts. The old ones have been removed and everything looks great. Now I'm trying to find the replacement nuts as used by GM. I have other choices but would prefer the same type nut. Any help with purchase or direction that I might go to find new ones would be appreciated.
Thanks in advance to the forum members
Thanks, for the response.
All of the vendors have mounting kit for the rocker molding kits but like most kits the components are a mix match of parts from current manufacturers I was just looking for the weld nuts. I can get a weld nut from McMaster Carr that is close for around $9.00 for 50.
