Which AC for my C3?
Cruising
Which AC for my C3?
I have just purchased a 1969 C3 it was originally an AC car but it has long since not worked.
What is the best retrofit AC to reinstall into the car. I have seen two so far that use the existing controls one is the vintage air Gen iv which looks like a good option. Similarly Classic Auto Air looks good also.
Both ar around the same price. Is there a difference in performance between the two? reliability? ease of installation? etc.
All input appreciated.
Jim Downey (06-25-2017)
St. Jude Donor '09
Vintage Air works for me. The biggest hassle is that it freezes me out constantly. The installation was a piece of cake. The hardest part was taking the old system out.
. . . . . . . . . .and a black knit hat?
Cruising
Thanks for that What do you mean by "It freezes me out constantly". Does it stop working or works too hard?
My plan after reading all over the net was vintage air,
Do the install then have an ac guy i trust check my work pull it down and fill it up,
Tina wants me to have the whole job done,
We will see...
We will see...
jr73 (07-01-2017)
St. Jude Donor '09
Works GREAT, in this Texas Weather. I run the AC blower speed mostly on Medium setting! If I run it on high , it gets uncomfortably chilly after a while.
Jim Downey (06-26-2017)
redcruz1120 (06-26-2017)
Cruising
Lovely looking car
thanks
thanks
Work good as best I can tell
George
Thanks, I checked out your build. I want to get the stock AC system in my 69 working, but the two Vette specialty shops discouraged me and suggested I replace the entire system with a new Vintage Air kit. My system is complete and sealed, but has no R12. I'm hoping to get the system checked for leaks and go from there getting it up and running.
Cruising
Hi I like the stock look, can you post more pictures showing the full set up? Mine has quite a few of the original components missing. Where would you suggest the best place to purchase is?
redcruz1120 (07-08-2017)
AC opinion
I just completed restoring my 69 BB coupe with factory original AC, I replaced the original POA valve with the up graded 134 valve unit that has the pressure switch, replaced the expansion valve, the receiver dryer, condenser, stayed with the Old style long compressor, evacuated the system added the Pag oil and 134 and it works great if you have an original system and hasn't been chopped up that's what I'd stay with, just my opinion. Good luck
Another vote for the original AC setup, it's plenty robust especially
with an upgraded condenser. Guess what it has that VA doesn't? VA only recirculates, no outside fresh air vent incorporated into it.
