Door is stuck OPEN
Old Jun 29, 2017 | 08:32 AM
ClutchHutch's Avatar
ClutchHutch
4th Gear
Default Door is stuck OPEN
So last night I was working on the vette and I opened the door to grab something and when I went to close it, the door just bounced right back off. I haven't had any issues with the door before this. I spent about 15 min playing with it but I cant seem to figure out exactly what it is. The door is unlocked, the latch is moving. Has anyone experienced something like this??
Old Jun 29, 2017 | 08:50 AM
gdm78vette's Avatar
gdm78vette
Do you have the car jacked up? If so lower it back onto the wheels. Frame twist may be causing door misalignment.
Old Jun 29, 2017 | 08:57 AM
D_Williams's Avatar
D_Williams
Can you move the lock between locked and unlocked. This happened to me in January and I believe it was frozen (it worked later that week)
Old Jun 29, 2017 | 09:11 AM
Bloodzone's Avatar
Bloodzone
https://www.corvetteforum.com/forums...uck-latch.html
Look at #2 post. His door was stuck close but I had same problem as you and this fixed it.
Old Jun 29, 2017 | 09:33 AM
ClutchHutch
4th Gear
YES it is raised.. ill lower it later. hope that works. im sure it will. Thanks so much!
To Door is stuck OPEN
