Fender emblem
Old Jul 4, 2017 | 07:33 PM
kingkohlmn's Avatar
kingkohlmn
Veteran: Marine Corps
Default Fender emblem
78, this fell off today while working on the engine. Figured there must be some type of special nut to secure it. But studs are too short, did a search and found out these were originally secured with double sided tape. I'll go with clear silicone. Might try and repaint also. What the heck another thing I never did on this car.
Old Jul 4, 2017 | 09:46 PM
biackbenz's Avatar
biackbenz
There is also a pin that protrudes through the fender wall. If you look real hard you can see it in the left side engine compartment. Past the brake cylinder. Very hard to see harder to get to. The right side is much easier once you remove the a/c unit. Might a zzz well pu) the engine too. LOL.
Old Jul 4, 2017 | 10:44 PM
The Punisher's Avatar
The Punisher
I would use 3m emblem tape before silicone
To Fender emblem
