1973 Diff Codes
Jul 9, 2017 | 06:34 PM
1973 Diff Codes
Meaning of 1973 Diff Codes
Either
AX N100 E 1
or
AX W100 E 1
3.36:1 what doe the other numbers mean.
Jim
Jul 9, 2017 | 10:47 PM
Jim,
AX- 3.36.1 Gear Ratio
W- Warren Plant
100- 100th day of the year. I believe April 10th
E- Eaton Positraction Source.
1 - First Shift
Hope this helps,
Tooch
Jul 9, 2017 | 11:01 PM
ax. code is for the HD BB 3:36 in my LS4 roadster .
Jul 10, 2017 | 12:09 AM
Where do you find the diff codes?
Jul 10, 2017 | 01:07 AM
Quote:
Originally Posted by
henrikse
Lying on your back look straight up at the bottom of the diff cover.
Jul 10, 2017 | 02:32 PM
Bottom of the differential in front of the cover. Soak rag with cleaner and rub and repeat till clean.
Jul 10, 2017 | 02:34 PM
Tooch1
Thanks for the help Tooch1. I knew someone here would have the answer.
Jul 10, 2017 | 03:53 PM
OK I looked and my 73 is AWW171E2 which I take to mean is 3:08 gears Warren plant Jun 20 Eaton manufactured 2nd shift correct?
This would correlate to my build sheet which said this car was born July 20 1973 and axle was AW
Sep 18, 2022 | 02:13 PM
Cruising
henrikse
My 1973 reads WW291E2. mine is a 3:08 ? Eaton 2nd shift?
Sep 21, 2022 | 11:09 AM
Cruising
rear codes
