starter
Old Jul 20, 2017 | 06:29 AM
harmoe's Avatar
harmoe
Default starter
1968 corvette - I needed to replace the dust shield on the bell housing, in order to do that I had to remove the hitachi starter motor . All went well ,I replaced the starter with the shims that were there. Bolted up nicely. Went to start the car starter sounds real bad , car will turn over but won'start, What next???
Old Jul 20, 2017 | 10:58 AM
henrikse's Avatar
henrikse
did the dust shield interfere with the starter shims?
Old Jul 20, 2017 | 12:19 PM
Dynra Rockets's Avatar
Dynra Rockets
Describe "sounds real bad". Is it a high pitched whine like a 60-70's Chrysler starter motor or a deep grinding sound?
Old Jul 21, 2017 | 06:47 PM
harmoe's Avatar
harmoe
It appears that the dust shield or clutch inspection plate makes contact with the flywheel. I might have to space it off the bell housing.
Old Jul 21, 2017 | 06:48 PM
harmoe's Avatar
harmoe
Old Jul 21, 2017 | 06:58 PM
mchar's Avatar
mchar
Why would you have to replace the clutch inspection plate?
Good thing you didn't beat up the ring gears -should be an easy fix.
To starter
