Fun in the garage!
Old Jul 27, 2017 | 05:27 PM
maj75's Avatar
maj75
Default Fun in the garage!
I sent the carb from my '69 L36 to Lars for a rebuild. I had just acquired the car and it hadn't been driven much. I was concerned about the gaskets having dried out.
While the carb was off I decided to tackle the leaky valve covers. The car has factory AC and still retains the smog fittings. My God, what a PITA. I was able to get all the bolts off but had to let a couple on the passenger side drop out the bottom of the car because I couldn't reach them with my fingers. Cleaned off the original hard as rocks valve cover gaskets using a scraper and a wire wheel. Straightened out the warped valve cover flanges. I chased all the bolt holes. I discovered that the original bolts were too short when trying to use the Permatex silicone with steel insert valve cover gasket. A trip (to two) to the hardware store set me up. I had to recruit my daughter to put some of the bottom valve cover bolts in place. Trying to stack the bolt, lock washer, 2 ground straps for the spark plug wires and get the bolt correctly started wasn't easy. Thanks to her help, we got it all buttoned up with all the ignition ground wires attached. I don't need the smog stuff, no inspections here, but I wanted to leave it because it's so original. I'm rethinking that and may remove the smog tubes and pump to make the car more serviceable.
Lars has sent the carb back weeks ago, so it was ready to go back on. I bolted it up with the correct base gasket sandwich and connected the throttle, return spring, vacuum hoses and throttle cable. A few cranks of the starter and she fired up for the first time in a couple of months. Ran perfect. Tomorrow to the DMV for plates!
I hoping to drive her to cars and coffee on Sunday, fingers crossed!
Old Jul 27, 2017 | 06:22 PM
maj75's Avatar
maj75
I was impressed with how clean the heads were. No gunk on the valve covers either.
Old Jul 27, 2017 | 06:50 PM
fever1's Avatar
fever1
Default 69 t-top
Oh How I know what your talking about finished doing mine last winter with the compressor off it was something else I used thick cork gaskets and original bolts worked good with some pressure changed plugs at the same time. Just an old 427 vete. L0l
Old Jul 27, 2017 | 07:21 PM
maj75's Avatar
maj75
I would have pulled the AC compressor but I could not figure how to get to the rear pivot bolt. I can see it, it's actually lose, but I can't reach it with a wrench or socket. The bolt that adjusts the tension on the AC compressor is also missing. If anyone knows the size I'd appreciate it.
Old Jul 27, 2017 | 07:53 PM
doorgunner's Avatar
doorgunner
2026 Loser of the Year
Good job on the repairs.....I use Castrol or Valvoline and the valve train is clean like yours after 150,000 miles on my 350 cu.in. Street truck.
As for help working on the engine........here Ya' go...........
She/grand daughter volunteered to install the shorty headers.
Old Jul 28, 2017 | 10:18 AM
fever1's Avatar
fever1
Default L36 fun
I'm thinking it is a 1/2 bolt with a 5/8 or 11/16 head Ill have to look at mine to tell, and yes that rear comp bolt is all most impossible to get to, I had all of mine apart due to replacing the POA valve with the new 134 later unit and AC hoses comp. etc. and it was a challenge.
Old Jul 28, 2017 | 12:22 PM
resdoggie's Avatar
resdoggie
Had a 1976 L-82, 4-sp
Royal Canadian Navy
A future Tesla engineer in the making?
Old Jul 28, 2017 | 01:53 PM
RMVette's Avatar
RMVette
She's styling with those shoes!
Old Jul 28, 2017 | 02:43 PM
maj75's Avatar
maj75
Not exactly OHSA approved footwear, granddad
I found the bolt, it's a standard 1/2 inch bolt.
Old Jul 28, 2017 | 06:04 PM
mortgageguy's Avatar
mortgageguy
She is going to make some young fellow a great wife someday!
Old Jul 29, 2017 | 12:14 PM
fever1's Avatar
fever1
I was thinking it was pretty big and thought was 1/2 in. but wasn't sure.
To Fun in the garage!
