C-3 A/C charge help
Old Jul 27, 2017 | 08:32 PM
Douglas Brown's Avatar
Douglas Brown
Default C-3 A/C charge help
A/c gage reading when attached after I press trigger. Acts like it is blocked. NO fluid going into unit/pump????
Is this where I hook up A.C canister to charge???IS thid the low side?
This the high temp switch?? I do not hookup to this??
This port on canister is on right side.very tight.
This canister port is more accessible, Is this the port I should be using??
Old Jul 27, 2017 | 08:59 PM
Z06LMB's Avatar
Z06LMB
Old Jul 27, 2017 | 10:50 PM
REELAV8R's Avatar
REELAV8R
You're on the right port. With the trigger pulled you should be seeing can pressure, 80 psi or more. With trigger released you should see system pressure. Between the red lines on the gauge.
If the pressure is only 50 with trigger pulled then the can is empty or not screwed on far enough and you are seeing system pressure unless the trigger is broke or something.
Old Jul 28, 2017 | 12:02 PM
Douglas Brown
I believe I may have found the problem, New equipment, old mechanic.
The car did not come with air, it is one of 3500 heat only production cars.
I think I had wires hooked up wrong and I am missing a Thermostatic control switch which would connect to the two wires I had connected to the low pressure switch. IF I touch them together the clutch engages.
thanks for the assistance....
DB
Old Jul 28, 2017 | 10:27 PM
7T1vette's Avatar
7T1vette
Are you charging it with 134a or R-12?? What refrigerant was in the system? That vintage GM A/C system used mineral oil as a lubricant and that is not compatible with 134a (unless you add ester oil to it).
Apples and oranges....be careful. If that system has been converted to 134a/PAG oil already, no big deal.
Old Jul 28, 2017 | 10:42 PM
Douglas Brown
Answers..Yes 134a....Pag 150 oil.....system is new: pump, hoses, Accumulator, switches wire harness....has not been charged. I did flush it out prior to adding oil to all areas 8oz max. then sealed it up. Have not tried to charge it until now, illness forced a halt to project.
Thanks for the caution note...
DB
Old Jul 28, 2017 | 10:50 PM
Duane4238's Avatar
Duane4238
Now you need to put a vacuum pump on it to draw everything out of the system before you charge it with the 134A.
Duane
Old Jul 29, 2017 | 05:40 PM
7T1vette's Avatar
7T1vette
Yep. All air and moisture have to be evacuated BEFORE charging with refrigerant.
Old Jul 29, 2017 | 08:26 PM
Wrecked82's Avatar
Wrecked82
This is the high pressure port.
This is the low pressure port and what you connect to when charging the system.
See my posts under the relevant pictures.
Old Jul 29, 2017 | 08:32 PM
'75's Avatar
'75
Just a heads up, I have ran into 2 different vettes that had that 90 deg adapter fitting on the low side port, but the installer had not removed the original schrader valve, caused interesting readings on the gauge.
Old Jul 30, 2017 | 06:14 AM
mikep3's Avatar
mikep3
I could never get the 90 degree elbow to work. Had to take out the compressor adusting bolt, install the filling hose and reinstall the compressor bolt.
After years of non functioning system I installed new seals, new hoses, accumulor, cross flow condencer and a Sanden compressor. Now it works here in Syracuse NY, maybe not in Florida, that would take a ac/heater box rebuild.
Old Jul 30, 2017 | 12:20 PM
Douglas Brown
That is good to know. The 90 is to give me room to work with. I believe I removed the Orig. Valve, but, will check now to make sure, Thanks.
DB
Old Jul 30, 2017 | 12:23 PM
Douglas Brown
Frankly; I thought it was a poor design and place to put it. location sucks.
Lets hope I have better luck.
Old Jul 30, 2017 | 01:18 PM
carriljc's Avatar
carriljc
I have a set of gauges with 90° connectors. Works well on my Sanden & Hot Rod Air because otherwise I could not connect to low side fitting. Of course, I wasted a can recently because I spaced that and attached to my regular straight-hose filler/adapter.
If folks can find a similar hose, then it may assist with some of these issues with connection access.
Old Jul 30, 2017 | 04:23 PM
Douglas Brown
I thought I would check out the suggestion about the needle valve. I was right I had taken out the orig. one.
And the other suggestion about connection hose being bad, so I disconnected the hose from the canister, WHY I thought it would close off when disconnected is beyond me, but it shot out of my hand and spun around the floor for a minuet. The hose when connected to the 90 deg. fitting is open.
DB
To C-3 A/C charge help
