1981 mods
Old Jul 30, 2017 | 10:44 AM
1st67convert's Avatar
1st67convert
5th Gear
Default 1981 mods
Just bought 1981 4 speed with with orig block, aftermarket heads, intake and 4bbl Weber carb. Cat converter not used, straight pipes to mufflers. Car runs strong, no blue smoke at start up or when driving. No codes observed on dash. Opinions on Weber vs. replacing with Qjet. And replacing cat and original pipes.
Old Jul 30, 2017 | 06:53 PM
M. Young's Avatar
M. Young
Default 1981
Whats the goal? No matter what you do to this motor its still going to be terrible. Trust me I know. You can wake it up slightly but every dollar you spend is one you could spend on a new crate motor.
Old Jul 31, 2017 | 04:29 AM
Antz81's Avatar
Antz81
Leave it as is. Original q-jet is computer controlled. If the PO has changed the cam as well then it may not work as intended. If you still have the original cam then you will be spending $$ for a fuel economy gain.
To 1981 mods
