Side Pipes Recommendations
This company offers ceramic coating as well. Looks spendy though.
http://swaintech.com/race-coatings/a...s-price-sheet/
In any case I'm glad to have the coating, it cuts down on under hood heat and is pretty resistant to chipping from gravel off the front tires. Looks good with little to no maintenance.
Thank you
I had a set of the Hookers (black painted) on a '77 Pontiac T/A, that I owned back in the day. The headers lasted only 2 summers of driving, before they rusted out at the collectors. A waste of $700............
Thank you
I have the Hooker headers and have had no problems with them as far as fitment or quality so far (7 years).
The actual tubes I don't remember the brand, might be hooker also. They are chrome and so far are holding up good as well. They are out of the line of fire from the front tire and don't see the heat that a header would.
For muffler inserts I put in the STS baffles. I like the sound and they are tunable for the sound you want. The center 1" pipe is plugged when they arrive and you can drill out or completely remove the cap it you want to get the sound you like.
There are other mufflers that sound pretty good as well. Remember that the quieter they are typically the more restrictive they are and visa versa.
Youtube is a good place to go to compare sounds of different muffler inserts. Most computer audio won't do the sound justice but it's good for comparison from one to another.
You can do a search here and get lots of opinions on different inserts as well.
Good luck
