Code ?
Old Aug 3, 2017 | 02:40 AM
2hero's Avatar
2hero
Default Code ?
What does 3345 380 CK-69 stamp mean on transmission ?
Old Aug 3, 2017 | 08:03 AM
Revi's Avatar
Revi
Is it a TH400?
CK - Corvette, base engine
69 - 1969
3345 - Transmission serial number
380 - 380th day from Jan 1, 1968
Old Aug 6, 2017 | 04:47 PM
2hero's Avatar
2hero
Default Code ?
Oh ok, so the day is Jan 16th 1969 counting from that day ? This is from 1969 Corvette Convertible Automatic Tranmission 350 ci. Is the transmission ID a partial VIN ID ? Is there a plate too not just stamped for the transmission identification such as build location etc that I read from other cars transmission information ? Thank you.
Old Aug 6, 2017 | 09:55 PM
2hero's Avatar
2hero
Default Code ?
If 1968 is a leap year, so there are 366 days in the year. Was this taken into account ? If V0116HZ is on my engine small block with 116 representing Jan 16 then there are 381 days BETWEEN Jan1st 1968 and Jan16th 1969, not 380 days as I have shown CK-69-3345 and 380 upper right ? Also does 3345 represent the transition ID not partial VIN number ?
Old Aug 6, 2017 | 10:56 PM
2hero's Avatar
2hero
Default Code ?
I found the tag. It's on passenger side aluminum plate with steel rivet above oil pan.
Old Aug 7, 2017 | 07:59 AM
Revi's Avatar
Revi
While your engine may have been assembled on Jan. 16 (V0116HZ), the transmission assembly date (380) has nothing to do with that.
The 3345 is the transmissions serial #, as in the 3,345th transmission built that year. It has nothing to do with your cars VIN.
If the transmission was original to your car, a partial VIN should be stamped here I believe.
If there isn't a partial VIN, then the transmission may be an over the counter replacement or there may be a partial VIN of a different car that the transmission was originally installed in.
Old Sep 27, 2017 | 11:40 PM
Cavu2u's Avatar
Cavu2u
Thanks Revi,
.. for showing me where to look for the transmission case's Serial # stamp. It confirmed it's the original TH400 that St. Louis dropped into my '73, as the last six digits in that lower red box area matched the VIN's last six.
Steve
To Code ?
