Door key would not turn lock completely vertical
Old Aug 3, 2017 | 05:05 AM
daleservices's Avatar
daleservices
1st Gear
Default Door key would not turn lock completely vertical
Door key would only turn the door lock to about 75 degrees instead of 90 degrees vertical thus not engaging the outside door handle in this 76 Corvette
Old Aug 3, 2017 | 06:13 AM
Red86Z51's Avatar
Red86Z51
Finalist 2020 C4 of the Year - Unmodified
C4 of Year Finalist (stock) 2019
The only way to really know what's going on with your lock movement is to remove your door panel, the plastic latch cover, and look inside the door at the back of the lock when you operate it. You're going to have to get in there to fix your problem anyhow. It's really not a hard job.
Old Aug 3, 2017 | 06:37 PM
rosros's Avatar
rosros
happen to my car and also a mr2. key does not turn all the way. shot some penetrating oil in it and it turns freely immediately. give it a try.
To Door key would not turn lock completely vertical
