Absolutely confused on steering column question...
Old Aug 4, 2017 | 09:49 AM
E.Murray's Avatar
E.Murray
Default Absolutely confused on steering column question...
It all started when I decided to replace the lower steering column bearing... It's a '69 (I think) standard column and I've had it apart four times trying to figure it out. But I'm at a loss and calling in reinforcements - that's you all.
When I turn the key, it just pushes the top sections of the column away from the main part. The only way, then, to get the car to start is to push on the wheel to hold it in place so the rod with actuate the ignition switch. I've printed off all the breakdowns I can find (including all Jim Shea's stuff) and cannot, for the life of me, figure out what I've done wrong. What holds the collar (the part with the ignition cylinder) to the rest of the column?
Old Aug 4, 2017 | 05:01 PM
corvgreg's Avatar
corvgreg
Emerging Vendor
The lock housing should be screwed down in 3 spots. There should be a diagram somewhere online to get an exploded view.
Old Aug 4, 2017 | 08:09 PM
TimAT's Avatar
TimAT
There should be 3 flat head screws that hold the upper bowl. Looks like it may be #35 in this picture.
http://jimshea.corvettefaq.com/?p=706
Old Aug 4, 2017 | 10:32 PM
Street Rat's Avatar
Street Rat
PM sent to E.Murray.
Old Aug 7, 2017 | 01:19 PM
E.Murray's Avatar
E.Murray
Do you mean these screws?
Also, while I'm at it, here's a picture of the problem. The top part pulls away from the bottom part (the brown paint used to be covered up).
Old Aug 7, 2017 | 01:24 PM
E.Murray's Avatar
E.Murray
Ignore the previous post. I see that you were referring to the bolts underneath the turn signal switch. I am positive they are there, so I was trying to avoid pulling that silly circlip again (for the 4th time...). But I think you may be right that those bolts are supposed to be what holds it together. Not sure what the deal is, but it's looks like I'll pull it apart again to look. Thanks for the help!
To Absolutely confused on steering column question...
