1978 quadrajet idle
Old Aug 5, 2017 | 03:51 PM
409/409's Avatar
409/409
Default 1978 quadrajet idle
I would like to set my idle up about 200 RPM's. Where is the screw? I can't seem to find it.
Old Aug 5, 2017 | 04:05 PM
raydog9379's Avatar
raydog9379
2 screws front side of the carb (towards front end of car) towards the bottom one on each side.
Old Aug 5, 2017 | 04:42 PM
KapsSA's Avatar
KapsSA
Active Streak: 90 Days
The idle adjustment screw is the one the cable controlled linkage rests against.
Should be right there on the side. Watch as you manually operate the carb linkage and you should see it.
Don't mess with the mixture screws.
Old Aug 7, 2017 | 12:12 AM
MGB's Avatar
MGB
St. Jude Donor '14
Agree with Kaps. That's where mine is on my '78. The two screws in front are the air mixture screws, be careful messing with them.
Old Aug 7, 2017 | 08:57 AM
raydog9379's Avatar
raydog9379
Well that explains why once I messed with my front 2 screws that my idle became normal.
Bubba jacked with all kinds of things there, and the idle was one of those. I think because he chopped off many of the vacuum hoses that he had to mess with the front 2 screws to adjust or make it not die, as once I fixed those vacuum lines then my idle was really jacked worse than before. Now I'm all good though, and it idles right on the factory #s.
To 1978 quadrajet idle
