Convertible top CD
Old Aug 6, 2017 | 05:48 PM
JBrooke825's Avatar
JBrooke825
2018 C3 of Year Finalist
Default Convertible top CD
Thinking of changing the black cloth top to a white vinyl.
Thinking I could probably do this next winter. Any ideas?
Plus where should I buy it from .
Old Aug 6, 2017 | 07:46 PM
mrvette's Avatar
mrvette
Just did the top on my '72, recommend it not be cold weather as vinyl is stiff as a board....70+ is good.....
second off, that rear bow on the top is a mess to work on, while attached to the frame....two bolts on each side/end and that loop comes off when you cut the old canvass off it, you can then put on a bench and note how that back rubber strip comes outta the slot, and most tops have a bead that goes in the same slot as the rubber gasket....it is much easier to work that whole back most section together on a bench, using a dull putty knife about 3-4" wide to force the rubber into the slot, then to reinstall the bow, and do the rest of the nasty......
I did my own top not long ago, and had to redo it, with tips from a pro....
OH the glue you want is HH -66 off ebay....meant to glue vinyl materials.....
OH, the deck gasket sometimes has a cord about 1/8 diameter inside the rubber of the gasket...you need pull that out first, and it really don't need be there, actually....not in my case anyway.....
Old Aug 7, 2017 | 05:58 AM
JBrooke825's Avatar
JBrooke825
Garage is heated so that won't be a problem. Sounds like I better
Find a cd to watch. Thanks again
Old Aug 7, 2017 | 11:03 AM
20mercury's Avatar
20mercury
Here is what info source I used which was great when replacing my soft top:
http://rowleycorvette.com/corvette_repair3.html
http://www.rowleycorvette.com/corvette_repair3b.html
Hope this helps.
Old Aug 7, 2017 | 11:20 AM
Mr D.'s Avatar
Mr D.
Al Koch sells a top install video for both C2 & C3, I used it to install my 65 top and it was a HUGE help in doing this. Not sure I could have done this the first time around without it.
Old Aug 7, 2017 | 01:04 PM
bj1k's Avatar
bj1k
Definitely go with the Robbin's top . They are the best top out there . Stay away from Al Knoch , they are inconsistent . However the Al Knoch video is a good guide for someone with limited experience in installing tops . Make sure the rear bow weatherstrip is not the cheap import type or you probably will fight it and probably will not get it to go in . The USA weatherstrips are easy to work with .
Old Aug 10, 2017 | 06:06 AM
JBrooke825's Avatar
JBrooke825
Hi, are you talking about the rear weatherstrip that sets on the rear deck?
Mine seems to be fairly new I should be able to reuse it. I think
Thanks Jim
To Convertible top CD
