1970 454 Fan Clutch Problems
Old Aug 7, 2017 | 11:13 PM
RussellD's Avatar
RussellD
Default 1970 454 Fan Clutch Problems
I have a 7 blade wing tip fan blade with original fan clutch that is worn out.Tried several Hayden fan clutches but hub diameter will not go though hole on fan blade.Its only like 2.3 " diameter.Anyone know where to get a clutch at reasonable price that would fit?
Old Aug 8, 2017 | 07:28 AM
Revi's Avatar
Revi
Why don't you get your original fan clutch rebuilt?
Old Aug 8, 2017 | 11:38 AM
jhudec's Avatar
jhudec
Yes. Get it rebuilt. There is a gentleman in Florida that does fantastic work.
Joe
Old Aug 8, 2017 | 11:42 AM
Mr D.'s Avatar
Mr D.
Are you trying to say the center hole of the fan not fit over the mounting flange that attaches to the water pump?
Old Aug 8, 2017 | 02:10 PM
RussellD's Avatar
RussellD
Yes ,flange of fan clutch will not fit through hole of fan blade.whats number of guy in Florida?
Old Aug 8, 2017 | 02:11 PM
RussellD's Avatar
RussellD
Joe
Do you have his number?
Old Aug 8, 2017 | 02:15 PM
RussellD's Avatar
RussellD
Even thought about grinding the mounting flange on fan clutch a little smaller?
Old Aug 8, 2017 | 04:18 PM
69Vett's Avatar
69Vett
Corvette of the Year Winner 2017
2016 C3 of Year Finalist
you have the wrong clutch, assemble.
...or the wrong water pump.
Old Aug 8, 2017 | 08:58 PM
Mr D.'s Avatar
Mr D.
I agree, impossible because the mounting pad on the fan clutch is larger than the water pump mounting flange.
Old Aug 9, 2017 | 07:46 PM
69Vett's Avatar
69Vett
delete attempt !
Old Aug 9, 2017 | 11:55 PM
RussellD's Avatar
RussellD
delete attempt !
well I decided to put the original fan clutch in storage for a possible rebuild later.found one at auto zone part number 9222711.it looks like a close replacement with same size flange and bolt pattern as original.its also made in the USA.
To 1970 454 Fan Clutch Problems
